Shift Knob Adapter
Old Sep 10, 2005 | 10:40 PM
8 is enough's Avatar
Shift **** Adapter
Got a question, I am thinking of a momo shifter. I am not a fan of the voodoo ***** not my style. I see that this adapter(see link below) should work for the 8 since it has the same shift **** specs as the miata. My question is does the adapter raise the shift **** higher? I have used the search function and saw that some one used the adapter but the written instructions do not make a lot of sense. Also when you look at the attached picture it does not look like right. Any comments or thoughts would be greatly apprecaited
http://store.miataparts.org/timomiad.html
Old Sep 11, 2005 | 11:04 PM
dazygirl415's Avatar
Sam, Scalliwag has a shifter similar to this. I don't know if it's a product he bought or if he made it himself, but it's worth looking into.
Old Sep 12, 2005 | 12:00 AM
Student Driver
I had to cut off almost an inch to get my Momo fitting correcly...
Wish I hadn't cut it because my OEM **** will no longer fit when I get rid of my 8...
Old Sep 12, 2005 | 07:36 AM
jenkins-crew's Avatar
Just get you an Ichibahn shift ****, mine works great.
Old Sep 12, 2005 | 10:25 AM
Pics of Momo and Ichibahn??
Old Sep 12, 2005 | 01:43 PM
Ichibahn:
http://www.ichibahn.com/frame2005.html
Goto producs / shift *****
Momo:
http://ltbmotorsports.com/shiftknob.html
Old Sep 12, 2005 | 02:07 PM
Wow! I didn't know there were so many choices out there.
Old Sep 12, 2005 | 02:39 PM
Just a few :D
Old Sep 12, 2005 | 05:28 PM
Nubo's Avatar
Lubricious
If it works for the Miata, should work with RX-8, the threads are the same. It also claims that it doesn't leave a gap between the **** and the boot so it doesn't sound like it's raised much, if at all. I'm assuming the Momo slides down further than the end of the insert.
Here are a couple of reviews from Miata.net. You might want to get specific with them about the particular model of **** you're planning on using....
http://www.miata.net/products/swknob...omo_adapt.html
Old Sep 12, 2005 | 06:19 PM
lethologica's Avatar
I don't mean to hijack your thread, but why aren't there any rotory shaped shift ***** similar to what is in there now? Mine is starting to show signs of wear around the edges. I'd like something that is made of a better material.
Old Sep 12, 2005 | 08:18 PM
That is the same reason why I am chaning my shifter, the wear on it pisses me off. The car is 2 years old, but the shifter is wearing.
Old Sep 12, 2005 | 08:20 PM
here is a link to the shifter i am interested in.
http://ltbmotorsports.com/mocoevoai.html
Digitz0070
55
Jul 25, 2017 08:40 PM
RX8mzda
Oct 1, 2015 10:17 PM
FubarI33t
Sep 28, 2015 08:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Digitz0070
Sep 25, 2015 10:58 PM
