Did I do damage?
Old Sep 9, 2005 | 04:59 PM
Krankor's Avatar
Klingon Grammarian
Unhappy Did I do damage?
So I found the first true flaw in the RX-8. The red-line beeper thing is HOPELESSLY not loud enough. I was driving along today, on a rather trafficky road that wasn't letting me open it up. So I had the radio on and wasn't worrying about it. At some point I guess the traffic opened up a bit, but I forgot to shift; I must've still been in second. Of course the car is so smooth and quiet that I never noticed, and I never did hear the little redline beep with the radio playing; I didn't notice I had screwed up until I felt the power start to make noticeable little lags, and I looked down at the tach and saw I was doing 9500RPM. No idea how long I'd been doing this for. Of course I instantly got off the gas, and shifted.
Haven't noticed any problems, but I'm still worried that maybe I did some damage? I know nothing about motors.
Krankor
05 Shinka 6MT
Old Sep 9, 2005 | 05:03 PM
Ike's Avatar
Ike
Blue By You
Should be fine, the ECU won't really allow you to do any major damage. Unless you were bouncing off the fuel limiter for a LONG time you have nothing to worry about.
Old Sep 9, 2005 | 05:07 PM
Glyphon's Avatar
脾臓が痛みました
^^^ like ike said, just the fuel limiter. you should be fine.
Old Sep 9, 2005 | 05:10 PM
wedge357's Avatar
ShinkaMan #748 SV6P
Looks like a warrantee killer... :D :D :D
Old Sep 9, 2005 | 07:03 PM
Raptor2k's Avatar
Club Marbles Member
No offense...but how did you not notice? How high was your radio volume? Even when I have my radio up quite loud, I'll notice the beep, if not the engine screaming.
Old Sep 9, 2005 | 07:15 PM
Aseras's Avatar
nothing done. heck I've dropped mine into 2nd instead of fourth at 80 mph and saw the tach go way past 10k ( like 13-14k ) and nothing happened.. better than 5000 miles ago too.
Old Sep 9, 2005 | 07:17 PM
valpac's Avatar
Ahead of its time
Been there. Kinda freaked me out a little, but no apparent damage. When you hit the rev limiter and fuel cut-off, it gets your attention right away before you can blow something up. Dont sweat it.
Old Sep 9, 2005 | 07:23 PM
NgoRX8's Avatar
On a few of my revs, I didn't hear a beep at redline. Usually I would but I guess if you stomp the gas it moves too fast to beep. :D
Old Sep 9, 2005 | 08:14 PM
cleoent's Avatar
n00b
you'll be fine, fuel cut off is 9400 engine could rev forever, it's the accessories that limit it. you're fine dude, dont sweat it.
Old Sep 9, 2005 | 08:43 PM
Krankor's Avatar
Klingon Grammarian
Thanks guys. You make me feel MUCH better. Yeah, what I experienced that caught my attention must've been the fuel cut-off (which I hadn't realized existed). The radio was reasonably loud, but not killer loud. But the beep itself is not very loud; wish they hooked it into the radio, so that it would be as loud as you have the radio set.
Or maybe it just happened to be at a pitch that worked with the music, so it wasn't noticeable.
Thanks again, al!
Krankor
05 Shinka 6MT
Old Sep 9, 2005 | 09:13 PM
beachdog's Avatar
You will never hear the beep if the radio is on at any volume. A lot of people never hear the beep at all. It is not loud and engine noise, road noise etc at redline are all enough to mask it.
Besides, it's a beep, not a beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep. It's only intended as a shift indicator, not to wake up the driver.
Old Sep 10, 2005 | 09:59 AM
Glyphon's Avatar
脾臓が痛みました
if i'm not concentrating on specifically listening for the beep, i almost never hear it. radio on, off makes no difference. the engine noise alone is sufficient to mask it.
i wonder if there's a way to transplant the FB buzzer in the 8 :D
Old Sep 10, 2005 | 10:23 AM
RotaryManiac's Avatar
1st time rotorhead
i think someone here did that
Old Sep 10, 2005 | 10:35 AM
rollerbldes's Avatar
Does the AT have a buzzer? Well in tiptronic mode?
Old Sep 10, 2005 | 10:41 AM
cLLcLe's Avatar
Just call me Circle
I believe a DIY for a louder buzzer is in order!!! Hahaha
Old Sep 10, 2005 | 01:14 PM
NgoRX8's Avatar
Yes, same beep, just at the auto redline.
Old Sep 10, 2005 | 01:18 PM
legokcen's Avatar
The Turkish Delight
No damage. That rev limiter is there for a reason. I've hit it a few times myself. The motor should be fine.
Old Sep 10, 2005 | 01:24 PM
legokcen's Avatar
The Turkish Delight
I did that too. The needle went up to 10.5K. Freaked the heck out of me. I was sweating it there for a while. That was about 22K ago. Car is great. I love the rotary.
Old Sep 10, 2005 | 01:33 PM
Genesis's Avatar
Driving Me Crazy
krankor, provided you don't let this happen too often, no worries, but going to 9.5k rpm without shifting to third is certainly not recommended. My advice is to get a rev meter which will "flash" in your eyes at the rpm you set regardless of the noise around you so you don't forget to shift
Old Sep 11, 2005 | 08:27 PM
juikster's Avatar
Im 8 drifting on a budget
A guy in a suped up mustang egged me on today for a showdown so I nodded. when we both launched off I had him on the start until I was just slamming it into 2nd the car just shut down just for a second or two ,just enough time to let him slip by but my car regained countiousness and off I go again on his tail but shut it down before the next light to ponder on what had just happened....I must of over reved the motor......Right?
Old Sep 11, 2005 | 08:37 PM
Rena my Rx8's Avatar
does ne one know how far exactly u can push the rpm safely?? i was always wondering, cuz im too scared i might do damage by pushing it past 9, jus wondering if ne one knows
Old Sep 11, 2005 | 08:42 PM
Diabolical RX8's Avatar
Drift Fanatic
If I had a MT RX8 I would find myself constantly wanting to go past 9k. But I wouldnt for warranty's sake.
Old Sep 11, 2005 | 08:48 PM
Glyphon's Avatar
脾臓が痛みました
you can only go to 9500 (unless you miss a shift). once you hit 9.5k, fuel delivery is cut and you feel a huge drop in power. and really, power drops off rapidly after 9000, so there isn't much point in going very far past 9k.
Old Sep 11, 2005 | 08:57 PM
kool, thanks guys, i wuz jus wondering :D
Old Sep 12, 2005 | 05:54 AM
L8APEX's Avatar
Smooth Criminal
I have only done this once, I could not hear the beep at all, becuase the tires were screaming so much. Donuts on a skidpad. :D
