bern
09-07-2005, 05:07 PM
How early are you guys going to start lining up at 7stock?
View Full Version : How early to line up for 7stock?? bern 09-07-2005, 05:07 PM From: XDEEDUBBX How early are you guys going to start lining up at 7stock? bern 09-07-2005, 05:08 PM Guys start lining up as early as 6:00am... so it's up to you. -Bern Jedi54 09-15-2005, 04:01 PM Line up to get in??? OR to show your car? bern 09-15-2005, 05:38 PM Line up to get in??? OR to show your car? Both, because it's one and the same!!! If you're not coming in a Rotary, then you can come a little later also... or if you are coming in a Rotary and don't care if you get a parking spot in the display grounds, which is the whole venue, than you can also come later. -Bern XDEEDUBBX 09-26-2005, 04:30 PM Bern, What about leaving the show early just in case? Will that be a problem? Outlaws eXtreme 09-26-2005, 04:55 PM If you park in the main lot, you cannot leave until after the Raffle portion.. which is around 3-4pm or so. :P bern 09-26-2005, 05:42 PM Bern, What about leaving the show early just in case? Will that be a problem? If you park in the main lot, you cannot leave until after the Raffle portion.. which is around 3-4pm or so. :P Close, but not exact... if you park in the main show lot, you MUST STAY UNTIL 2:00PM. If you can not stay until 2:00pm, you must park in the street display area! You will be asked before going into the venue, on the morning of. -Bern hookupshop 10-03-2005, 06:29 PM We shall be there this Saturday displaying our new project RX-8. Save a good spot for us if we can't get there that early like 6am. We're coming from San Diego. Can't wait...for Sat! |
