hp problem
Old Sep 4, 2005 | 05:46 PM
chrik's Avatar
hp problem
I have a little question for you, I check for the buy of a use RX-8 and I have seen different HP for the same year of production, and big difference, under 180hp for some car and 238 for others, I don't understand ??
Old Sep 4, 2005 | 05:58 PM
poolsidenaz's Avatar
Auto = 180
5spd MT = 238
Old Rotor's Avatar
Yes the 6spd has 238hp and the 4sp/auto has 197hp.
Old Sep 4, 2005 | 06:01 PM
Fanman's Avatar
Welcome to the board. The difference in hp stated on the board is hp at the crank & hp at the wheels. There is a phenomenon called driveline loss, where you lose hp because it has to go through various mechanical parts in your car (ala transmission, driveshaft, diff., etc.). Usually it is calculated at about 15% to 18% loss. So when somebody states 238 hp, that is the hp at the crank/engine. RX8's average around 180 hp at the wheels.
Old Sep 4, 2005 | 08:23 PM
mmats69's Avatar
93.5 octane
Fanman makes a good point as usual and it amazes me as well about driveline loss.
Old Sep 5, 2005 | 12:02 AM
xrider01's Avatar
127.0.0.1
i've read elsewhere that the 8 loses about 35hp at the wheels from the crank, not nearly 60hp.
Sounds like a street race - which we do not condone -Abbid
SRT-4 specs
and everybody should know the RX-8 specs :p.
Old Sep 5, 2005 | 12:11 AM
Fanman's Avatar
I've only seen 1 RX8 put down 200+ whp stock (238-35 = 203). Most people dyno at around the 170-190 whp range. Do a search, everybody pretty much does around that. There was a group in the Northwest where they all dynoed high (particular dyno), and ones that dyno low (mustang dyno).
The 0-60 & 1/4 mile (also 0-100) times say we are indeed closer to the 180 hp vs. where a 238 hp car should really be (around that low 200 mark). This car really is running around 215-220 hp (that would dyno out to about 180 whp).
Old Sep 5, 2005 | 12:30 PM
chrik's Avatar
tanks a lot for your answers
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
