Heat/AC temp control / air mix actuator (restricted part?)
Old Sep 1, 2005 | 10:48 AM
fray's Avatar
On my RX-8 I am having a problem with the air mix actuator/temp control. Basically what is happening is the two extremes work (all the way cold, all the way hot), so all of the dealer/Mazda diagnostics come back as "it works correctly". (So I guess I'm lucky that my complaint is my car gets TOO cold w/ the AC on.)
However, if you watch the air mix actuator under the dash it never moves as you move the temp control **** between the extremes (unless you tap it, then sometimes it will move/twitch.)
Anyway, the dealer was able to replicate it after I pointed out the air mix actuator, they worked w/ Mazda tech support to diagnose and order parts. (Unfortunatly they never told me what the part was...)
However, the dealer told me that it may take a few weeks to get in the part. They told me the part was a "restricted" part, and only Mazda themselves could order and ship the part for replacement.
Can anyone explain to me what a "restricted part" is?
Thanx,
Mark
Old Sep 1, 2005 | 01:13 PM
fray's Avatar
Well, I found out what the "restricted part" was. The "heater control module".
[Note: originally they told me it was the whole radio, apparently the guy who called was mistaken.]
So 'er.. what is a heater control module?
Last edited by fray; Sep 1, 2005 at 01:27 PM. Reason: Fix radio -> heater control module
Old Sep 1, 2005 | 01:53 PM
AC8's Avatar
AC8
She Always Beeps so Sweet
Why?
Why would this be a restricted part?
Old Sep 1, 2005 | 02:16 PM
KYLiquid's Avatar
Oil Injection
does it maby contain a toxic/controled chemical?
Old Sep 1, 2005 | 04:21 PM
MDRX8's Avatar
Check my threads MDRX8 this is what I have been complaining about
The system does not work!!!
Old Sep 1, 2005 | 04:23 PM
MDRX8's Avatar
https://www.rx8club.com/series-i-tech-garage-22/does-your-c-do-68185/
Sifu
Aug 30, 2015 10:51 PM
06rx8nate
Aug 4, 2015 08:29 AM
RotaryRider
Jul 20, 2015 07:05 AM
AussieGray
Jul 16, 2015 03:58 AM
