Help Needed : Engine Lost Compression
Old Aug 30, 2005 | 06:56 AM
RX8 Brunei's Avatar
Rotary Lover
From: Brunei: Where Ricers show off their fugly rides
My 8 had stalled since 4mths back. All the mechanics here in Brunei claimed the engine had lost compression. Do i need to replace to new engine or rebuild it or any other option? Engine is hard to start since i remove the cat converter. after a while i drove the car, idling drop drastically, resulting in idling problem. After sometime i manage to start the engine, since the idling is not good so i press the accelerator for around 15mins. Smokes coming below the car & i found the the rear o2 sensor wire is melted.
Really need u guys opinions to solve this problem. Thanx
Old Aug 30, 2005 | 07:43 AM
RX8 Brunei's Avatar
Rotary Lover
Oh btw, lists of mods :
HKS RS Kit, HKS Legamax Muffler & Custom Pipe (replace cat). Adding more info, i've checked the spark plugs. Rear plugs are wet but front plugs are dry. Is it possible the front rotor ain't working or there's something problem with the MAF sensor??
Old Aug 30, 2005 | 08:08 AM
tuj's Avatar
tuj
You do need a special tool to check the compression on a rotary engine, however if the shop told you that its lost compression, the engine is probably done for. If its under warranty, you should try to get it replaced, otherwise the engine needs to come apart to see if it can be rebuilt or not.
Take it to Mazda or a rotary specialist and get the compression numbers for each face of the two rotors. My guess is that you have lost compression on at least one rotor, meaning the engine is shot.
Old Aug 30, 2005 | 02:56 PM
Blue87Sport's Avatar
Rotary only since 1980
Originally Posted by RX8 Brunei
... i press the accelerator for around 15mins. Smokes coming below the car & i found the the rear o2 sensor wire is melted.
Please read the thread on the thermal damage recall https://www.rx8club.com/series-i-trouble-shooting-95/recall-thread-mnao-suspend-rx-8-deliveries-66002/
Sustained high RPMs at a standstill can damage the underside of the car including the gas tank. I don't know the status of the recall in your country but you could have heat related damage. It may not be related to the engine problem but you should have the dealer look at.
Good luck.
Old Sep 1, 2005 | 09:04 AM
Mazmart's Avatar
Try to take some good pictures of your spark plugs and repace them while your at it if you haven't already done so. I'd like to see what your old ones look like. Part of your description sounds like a flood condition which will definitely act like and literally reduce your compression.
Paul.
Old Sep 1, 2005 | 06:23 PM
beachdog's Avatar
Is yours an automatic?
Do you have only 1 oil cooler?
I think that the climate by you is similar to Las Vegas in the US. We have a rash of blown engines there.
Old Sep 4, 2005 | 07:04 AM
RX8 Brunei's Avatar
Rotary Lover
Nope. 6spd MT. Only a single stock oil cooler. Could be becoz of the climate but my engine's not blown. Any idea mate?
Old Sep 4, 2005 | 07:21 AM
RX8 Brunei's Avatar
Rotary Lover
Originally Posted by Blue87Sport
Please read the thread on the thermal damage recall https://www.rx8club.com/showthread.php?t=66002
Good luck.
Yo blue!! Thanx 4 the thread. My feeling said that i'm having this heat related damage. The dealer won't give me warranty/engine replace since i've void it. But hopefully they could do something about it (dealer don't have any rotary speacialist).
Old Sep 4, 2005 | 07:35 AM
RX8 Brunei's Avatar
Rotary Lover
Paul.
i've change to new spark plugs be4 the car stalled. 1stly i thought engine was flooded. I tried the deflooding procedure but it won't help. maybe i'm too late to tackle the problem since it's having the hard start problem for around 1-2 mths after i made the modification.
vapor2
Nov 3, 2020 03:38 PM
Pelleilee
Sep 29, 2019 10:07 AM
ShadowGryphon
Jul 29, 2015 05:40 PM
CMRine04
Jul 29, 2015 02:07 PM
Bamaham
Jul 23, 2015 08:08 AM
