help with dipstick reading?;
Old Aug 27, 2005 | 03:32 PM
miker2005's Avatar
about to do my first oil topoff; 1000 kms in a month and the oil level had dropped from the top full mark to just below the highest of the three dimples/holes;
my question is, should i top it off now or wait till the stick is closer to the bottom, as the manual suggests; if i top it now, apprx how much oil to get from highest dimple to the full line?; i cant imagine it would take much to fill it fomr here but i dont want to overfill; thanks in advance;
Old Aug 27, 2005 | 04:12 PM
staticlag's Avatar
The Professor
The more often you check and refill your oil, the better.
As soon as you notice it is low, pour some in.
Theres no real technique to it, just pour some oil in and check the dipstick, and keep doing it until it is back at the top line, being careful not to overfill. I'm guessing your about half a quart low.
The manual would say: check your oil everyday, but people wouldn't really like to hear this car is so high of maintenance.
Old Aug 27, 2005 | 05:14 PM
Brice-RX8's Avatar
Just check it once a week when you are about to wash it if you are as picky as me. I keep it topped off and most of the time slighly more than full just for good measures.
Old Aug 27, 2005 | 06:11 PM
Go48's Avatar
Check this out:
http://www.finishlineperformance.com...7-04-1438b.pdf
Old Aug 27, 2005 | 06:29 PM
miker2005's Avatar
go48; great link; thanks
Old Aug 27, 2005 | 08:53 PM
Go48's Avatar
Sure, anytime.
Old Aug 27, 2005 | 09:49 PM
ZoomZoomH's Avatar
Mulligan User
the first dimple from FULL is about .125 qt IIRC :p
Old Aug 31, 2005 | 09:27 PM
staticlag's Avatar
The Professor
For the new dipstick, can you just waltz in and request a new one?
Old Aug 31, 2005 | 09:50 PM
ZoomZoomH's Avatar
Mulligan User
^i pretty much did just that... :p
Old Sep 1, 2005 | 06:09 AM
Go48's Avatar
Well, you can certainly do that, but it will likely be at the descretion of the dealer if they will replace it gratis. Best to tell them you are having difficulty checking the oil because you can't see the oil on the stick.
Old Sep 19, 2005 | 11:55 AM
arrow_choi's Avatar
Yesterday, my8's motor oil was about half full, so I poured half bottle of oil into the engine. Then I checked the dipstick......Holy Cow!!!! The oil level was all the way up!!! I overfilled my 8 with half bottle oil?! I checked the dipstick again few times, and it showed the same.
I knew it must be something wrong with the dipstick reading, so I pulled it out again and twisted 180 degree and put it back and read it again! Wala!!!! It showed me 80% full, which make more sense.
Then I realized that the design of 8's dipstick is not straight, but a bit curve. So I wonder that you have to put it in a correct orientation in order to read the right oil level.
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
XianUnix
Sep 29, 2015 03:48 PM
Trekk
12
Sep 25, 2015 03:08 PM
