Guages and Meters
Old Aug 26, 2005 | 11:08 AM
morganoh's Avatar
Guages and Meters
I'm buying some Meters and Guages.
Initially I wanted 3 guages. Water Temp. Oil Temp and Oil Presure.
But saw the Knights sports Gauge pod and it can only hold 2 gauge.
So was wondering can I do away with the Oil Pressure? cos our car already has a Oil pressure gauge and furthur more the reading always stays at around the same value. so if theres a drop in the car oil pressure meter. I would be able to know right? so theres not need for an alternate Oil pressure gauge?
Can any guys please advice me on that
Morgan Oh
Old Aug 26, 2005 | 12:05 PM
PUR NRG's Avatar
The stock oil pressure has a pretty wide range--from 10psi at idle to 80psi at higher RPMs. As others have commented the stock gauge is basically an idiot light that stays in the middle as long as there's any pressure at all. 10 psi may be fine for idle but you're in trouble if it doesn't go up under load.
I went with SPA Design dual digital gauges. See the fourth picture down for additional info. http://www.hi-impact.org/ryang/modif...x8_custom.html
________
Infants wellbutrin
Old Aug 26, 2005 | 07:19 PM
watoke's Avatar
RX-8の魅力満載
The "Oil Pressure" meter display on our RX8 is an idiot. CMI.
Get the 3 guage (Water Temp, Oil Temp & Pressure)
Dunit the guage pod, just place it on the dashboard using the stand that comes with it (save $$), just like me :p and I got all the six defi guages :D
Old Aug 26, 2005 | 07:46 PM
HardHitter's Avatar
Do you have any pictures of your setup?
Old Aug 26, 2005 | 08:55 PM
rotarenvy's Avatar
cool set-up!
Old Aug 27, 2005 | 05:59 AM
morganoh's Avatar
Thanks PUR NRG and Watoke.
guess I would have to buy all 3 gauges after all.
Has any one seem this ?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7996259687
its a gauge pod that hold 52 mm guages. thinking of buying it and make the hole bigger so that it can hold 60mm guages
Old Aug 27, 2005 | 06:11 AM
coupe07's Avatar
SC 300HP!!
ur bro shd be able to custom it mah....
Old Aug 27, 2005 | 07:30 AM
morganoh's Avatar
he has too many jobs on hand. can't ask him to push away the business just to make this pod for me..
If I could find it in the market readly , I would just buy it n no need to wait and trouble him.
Old Aug 27, 2005 | 07:47 AM
Genesis's Avatar
Driving Me Crazy
Custom jobs are the best, but I REALLY like this gauge pod from fujita...perfect for three 60mm Defi's
Old Aug 27, 2005 | 07:51 AM
morganoh's Avatar
I believe that u would have to cut the front dashboard in order to install the Fujita pod.
I'm looking at something that need not do any alteration / cuting into the car parts. Just a stick on pod would be best.
Old Aug 27, 2005 | 08:05 AM
Genesis's Avatar
Driving Me Crazy
It's a stick on bro, have a closer look at the pic. I'm not sure how they handle the cables tho....
Old Aug 27, 2005 | 09:58 AM
Siesta's Avatar
Genesis: I think that gauge pod is only for 52mm n
unfortunately defi BFs only come in 60mm.....
Unless of cos fujita has made a pod for 60mm gauges im not aware of :D
Old Aug 27, 2005 | 10:43 AM
Genesis's Avatar
Driving Me Crazy
That's true Siesta...52mm was the norm, however I heard that 60mm is now compatible with the fujita gauge pod....I'll get a confirmation and revert.
Old Aug 27, 2005 | 03:18 PM
sqflyer's Avatar
Heavy Machinery Operator
Genesis, I believe the Fujita gauge pod requires cutting the top cover. We already have a couple of guys that got this exact Fujita gauge pod and they had to cut theirs. It's 52mm and I don't see how it can be compatible with 60mm gauges looking at how fitting the 52mm gauges sit in that picture. I'd be interested if they have a new model that can hold 60mm gauges. Please check.
Old Aug 27, 2005 | 09:56 PM
Siesta's Avatar
yup, unfortunately the feed gauge pod(unless they made a new on) requires cutting the top cover to run the wires and fits perfectly for the 52mm gauges only. Unless maybe you cut ahole on the pod itself and run the wires outside but it'll prob look messy. Sacrifice for looks? :D
Old Aug 28, 2005 | 09:37 AM
coupe07's Avatar
SC 300HP!!
the one that can fit 60mm gauges is from RE AMEMIYA.. however the price of that may set u guys back.....
Old Aug 28, 2005 | 10:02 AM
Genesis's Avatar
Driving Me Crazy
Coupe, can you direct to a link with pix? Price is no object...as sqflyer says, resistance is futile :D
Old Aug 28, 2005 | 10:05 AM
lennon's Avatar
Re-Amemiya meterhood for 60mm
Old Aug 29, 2005 | 11:51 AM
watoke's Avatar
RX-8の魅力満載
I think i did upload the pic before, maybe u do a search u should b able to find it ... :p
Old Aug 29, 2005 | 11:53 AM
watoke's Avatar
RX-8の魅力満載
Gen, how much u did your HKS air-intake at GR? U tink they still have stocks?
Old Aug 30, 2005 | 08:58 AM
Genesis's Avatar
Driving Me Crazy
it was $1k bro...dunno if they have stock right now, but I was there last weekend and didn't see any. They order and it comes in pretty quick tho. Great intake...I simply luv mine, everytime I step on the gas
Old Aug 30, 2005 | 09:02 AM
Genesis's Avatar
Driving Me Crazy
That's nice lennon, thx for the pic. I still prefer the fujita pod but it's not available for 60mm gauges....dang.
Old Aug 30, 2005 | 09:16 PM
takahashi's Avatar
Can you make the 52mm Defi meters in red rather than green? That will solve my problem.
Otherwise I will have a digital display which save a lot of money too!
Old Aug 31, 2005 | 01:54 AM
sqflyer's Avatar
Taka, yes it's been done. In fact, I think both zavhan and linus changed their green 52mm Defi gauges to red. As far as I know, it's just a simple open and change bulb thing but it voids any warranty you might have on your Defis. The Digital is limited in the number of gauges it can display at a time, right?
Old Aug 31, 2005 | 02:21 AM
coupe07's Avatar
SC 300HP!!
yup... our guys have been there n done that!!!! from green to red!! :D
