How do I get higher fuel cfm?
Old Aug 22, 2005 | 07:06 PM
Sapphonica's Avatar
PingMobile
Are there bigger injectors and a higher-capacity fuel pump available for the RX-8?
I'm not up on rotary engineering enough to know which injectors (or all) need to be upgraded to support hi-rpm/hi-boost.
If these parts are available, please let me which vendor(s) sells them & approximately how much I should expect to spend. If this info is already posted somewhere (I did look), please point me to the correct thread(s).
Just so ya'll know, depending on cost, I might try to find the upper HP capacity of the GReddy. We've already seen the fuel start to go a bit lean at higher boost/higher RPM (8 psi 7k+ rpm), so pushing it higher might require more capacity. Either that or the ECU is pulling fuel?
Old Aug 22, 2005 | 07:28 PM
rotarygod's Avatar
The upper horespower capacity of the Greddy is right around 300 hp. It's not fuel limited. It's airflow limited. The turbo is getting maxed out.
Old Aug 22, 2005 | 07:31 PM
Moostafa29's Avatar
Storm Trooper
Send the turbo to Mazsport to get upgraded.
Old Aug 23, 2005 | 01:07 AM
Sapphonica's Avatar
PingMobile
Is there another turbo that will fit in the GReddy housing?
Old Aug 23, 2005 | 01:08 AM
Sapphonica's Avatar
PingMobile
Has the 300 HP airflow limit been proven empirically, or does it have some other basis?
Old Aug 23, 2005 | 01:21 AM
rotarygod's Avatar
It's been more than proven. It is now a very well known fact. Many people have shown that boost rapidly falls off at higher rpm's due to inability to flow more air. The turbo is just plain and simply, too small.
Old Aug 23, 2005 | 02:02 AM
Sapphonica's Avatar
PingMobile
Oh, it's a size thing...my poor GReddy!
Old Aug 23, 2005 | 02:15 AM
rotarygod's Avatar
It was designed to do a certain job and do it well. That is to be a nice power upgrade over stock and have quick spool. It does that quite well. You can't have this and still have the efficiency to make big power though. There is always a tradeoff. Greddy designed a kit around street performance with a modest gain. It's a nice turbo but don't expect miracles out of the little guy. You will need a bigger turbo for that. Fortunately Mazsport is working on a compressor wheel upgrade for that turbo which should be able to take you over 300 hp. This doesn't mean it will do 400 or 500 hp though. You'd be surprised just how fun your Greddy turbo can be with proper tuning at around the 300 hp level. Don't get so much hooked up on power numbers. Results are more important on the street than on a piece of paper. You've still got more potential left in your system if you are still using the eManage. get it tuned and see how well you like it. You might be surprised just how fast that car can really be with that turbo.
Moostafa29's Avatar
Storm Trooper
Call Scott at Mazsport. You may get led in the right path.
Old Aug 23, 2005 | 01:11 PM
Sapphonica's Avatar
PingMobile
Thanks for the tip, M. Scott confirmed they will have a killer product available for GReddy owners very soon (I also don't want to steal his thunder...I'll let him post the juicy details).
I'm stoked!!!
Old Aug 23, 2005 | 02:07 PM
Moostafa29's Avatar
Storm Trooper
Told you. I should be sending mine in later this week or next, just need to talk to him again and work out some more details.
tbiggybig
35
Jul 14, 2022 06:14 PM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
