Oil pressure?
Old Aug 14, 2005 | 11:19 AM
faffy's Avatar
DIY: oil pressure?
Is there a method to measure oil temperature easily?
Old Aug 14, 2005 | 03:40 PM
zoomzoom_8's Avatar
Sure, you have to buy a oil temperature gauge, I have the Defi D mounted in an A pillar mount and an oil filter sandwich plate to go in between the oil filter and where the oil filter screws onto the engine. Install the sensor there, connect the wires and you are reading your oil temperature! most vendors carry the Defi D gauges, the oil filter sandwich plate you will have to pick up at japanparts.com.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
tgaffner
Sep 7, 2015 08:49 PM
