OEM foglights-what am I doing wrong
OK, so I got a set of OEM foglights off of a fellow member here so I have no instructions. I decided to install them this afternoon. Looked in the owners manual and figured that installing them would be similar to changing a bulb.
Manual says take it to the dealer to change the bulbs. But it provides me pictures of how to get to the general area through the tire well.
I remove the front tire and most of the clips to expose the backside of the nose and oil cooler. I feel around, find the screws to the blanking plates where the fog lights are to go. I remove the three screws and finally remove the blanking plates.
I work the fog lights into the general area and start to line up the screw holes, but no matter what I do, they interfere with the oil cooler. I notice that because of the light housing, they are wider than the blanking plate, particularly on the side where just the light is.
What am I doing wrong? Do I have to move something or is it just so close that it has to be in just right? I don't really want to remove the front nose to do this, but is that the only way?
Has anyone else done this installation? If you have the old directions that would be great too.
Please help.
Mike
Please help.
Mike
Removing the front nose is the easiest way to do the installation.
Here are removal instructions:
http://www.racingbeat.com/PDF/RX8nose.PDF
Are you implying that that is the only way to install them? Wil taht eliminate the interference issue? I don't see how....
What worries me is the refitting issues some have had when reinstalling the nose.
Mike
Mike
Unless you have incredibly small and agile hands, yes it is going to be your best bet.
Refitting Issues? I've been around this board for a year and haven't heard of anyone having refitting issues.
Concur w/ Staticlag^, It goes back on easier than it comes off, and I have to remove it again this weekend to attach the CAI to my REVi. Pull the nose bro', it makes life much easier!
Originally Posted by zoom44
link please? i havent seen this.
Don't recall if there was a thread or if this was a bunch of pm's.
Zoom and all,
See above, that's what I remember reading about. It's on this DIY forum, search for removing the nose.
I just can't believe I can't install them from the rear. I got the blanking plates off. I just couldn't get the light into position. Oh well, I've been wanting to get the front lip too so I'll do both at the same time.
Thanks all.
Mike
Thanks all.
Mike
Originally Posted by beachdog
Some of us have had an issue with the gap between the leading edge of the hood and the bumper cover after multiple removal/reattachments. One of our resident techs advised me to loosen all the 10mm at the bottom of the tray and have someone lift the bumper cover while retightening all the bolts. Easy fix.
I'm glad I stopped by this thread. I asked once before about this in here somewhere but I don't think I got a definative response. After my second air dam install by the dealer I noticed a wider gap there,took it back to the dealer and they said it's not adjustable. Thanks beachdog I may try to re-adjust it myself. Now back to our regularly scheduled programming. :D
Originally Posted by tiggerlee
Not to hijack your thread agoodcave but...
Okay, looked at an RX-8 at work with the fog lights and saw my problem. I assumed the light sat beside the oil cooler when in fact, it blocks it slightly on the side and the light sits ahead of the oil cooler.
So today, I tried it again. Jacked up the left side, removed the tire, removed most of the access panel clips in the wheel well. Contorted my hands, removed the 3 screws from the cover plates and installed the fog lights without removing the nose. Yes, you must have small hands - which I do and it takes a little time and concentration to put the screws in blindly, and then guiding the screwdriver onto them blindly. But, it can be done. Took about 45min. for the driver side and 15min. for the passenger. Don't know if I saved any time, but I hate plastic clips and if I broke one, the dealer is 20miles away!
I still need the wiring pig tails to go from the lights to the harness. Anyone know what brand and model the electronic connectors are?
Mike
Mike
Your 8 should come with the connectors bud. I didn't have the stock fogs. I found some connectors attached to the inner wall next to where the fogs hook up. Just attach those and install the the wand to your blinker goes, and you should be done. Did you get the wand with your fogs?
TxRx8, I'll take a look for the wires. I found some further back in the wheel well and I assumed they were them. They were too short tho' so I assumed there was a connecting wire.
As far as the wand goes. no. I did not get that. I bought them used off a guy here.
Mike
Mike
You found 'em! Those are them. Just pull 'em out from where they're attatched. As far as the wand goes, you'll need it if you want to turn the fogs on, buddy. Those connectors run straight to the wand fog switch.
Learners_Permit
Sep 27, 2015 07:38 PM
