Rear Rotary brake lite?
Old Aug 12, 2005 | 09:14 PM
RX-8 Sake Sipper's Avatar
Question Rear Rotary brake lite?
I am a new owner of a Sunlight Silver Sake Sipper and I am loving it.
Just yesterday I was cruising down the road when I heard the 'beep,beep' as a yellow RX-8 pulled up beside me and then passed my car. I followed alone behind until we came to a redlight. When he braked the rear Rotary emblem lit (bright red it was)up. I have been searching the internet trying to find one of these brake lights. Does anyone have any idea where they are sold? I guess it could have been home-made but it was surely eye-catching.
Old Aug 12, 2005 | 09:32 PM
tiggerlee's Avatar
May Cause Anal Leakage
Here's a DIY. https://www.rx8club.com/series-i-do-yourself-forum-73/diy-rear-rotor-light-65543/
Old Aug 12, 2005 | 09:36 PM
tiggerlee's Avatar
You can also order them from Japanparts.com http://www.japanparts.com/shop/shop....Lights%2fBulbs
Old Aug 13, 2005 | 11:00 AM
Yippers!
Thanks for the info Tiggerlee. I believe I will make my own as the market versions are pricey.
Old Aug 14, 2005 | 09:17 AM
modena's Avatar
Modena
Looking for this?
http://www.verlinden-productions.com...ear_Fog_Light/
Old Aug 14, 2005 | 05:06 PM
EsCoBaR1's Avatar
^^If these are the ones your looking for they sell them at mazdaparts.com around $204
Old Aug 15, 2005 | 08:37 PM
Thanks.
Thanks for all the help.
I built my rear lite yesterday for about $35.00.
I will post pics later.
I went to the local Pepboys(auto parts store) and bought a rear brake lite assembly, wiring , connnectors and the bulb.
I removed the polished rear rotary accent piece from the rear and used it to draw out a pattern on an old set of Ford ranger taillites. Once I had the plastic cut I sanded it smooth on the sides. I then used Goop household glue to attach the lens to the accent piece. (The Goop is so strong it will glue water together). I then drilled the hole, ran the wires to the left rear brake light and use in-line connectors to splice the new brake wiring to the factory brakelite wiring. I used a small amount of Goop to secure and waterproof the new brakelite assembley, install the brakelite and replaced the lens/accent piece with double-backed tape as is done by the factory.
I embellished the lens with a thin piece of metal air-conditioner tape around and on the front edge of the lens. This tape is actually metal and will not come loose once applied and it looks so cool..
For about 2hours work and $35.00 I have a fantastic looking third lite.
Old Aug 15, 2005 | 09:04 PM
NVMYGT's Avatar
IM2BZ2P
Post pictures immediately! That's exactly what I'm looking for.
Old Aug 22, 2005 | 03:43 PM
EsCoBaR1's Avatar
Genius! Way worth it then paying 200 bucks. Post pics so we can see, i was thinking about buying a red emblem that you place in the middle of the accent but if you made one on your own id rather do that.
Old Aug 24, 2005 | 10:27 AM
ZZ8's Avatar
ZZ8
Yada, yada, yada...
"RX-8 Sake Sipper", POST THE PICTURES PLEASE!
Old Aug 24, 2005 | 12:35 PM
Tamas's Avatar
Registered Lunatic
I think this just begs for a step-by-step DIY with pictures :D
Old Aug 24, 2005 | 12:38 PM
ZZ8's Avatar
ZZ8
Yada, yada, yada...
I agree.
Old Aug 24, 2005 | 12:45 PM
KYLiquid's Avatar
Oil Injection
im interested to see the final product
Audio Concepts ATL
Sep 26, 2021 01:59 PM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
thewatcher101
Jul 27, 2015 09:44 PM
AussieGray
Jul 16, 2015 03:58 AM
