Ignition tuning with turbo
Old Aug 8, 2005 | 10:53 PM
cretinx's Avatar
Has anybody played around with ignition timing with their e-manage on a turbo?
I'm assuming you need the ignition harness, correct?
I'm just going with colder plugs for now . . . . good idea or bad?
Old Aug 8, 2005 | 11:42 PM
zoomzoom_8's Avatar
General consesus on the plugs is that it is a good idea, colder plugs should help to decrease chance of detonation. Although, i am wonering how the 8 will run this winter with colder plugs. Not sure if that makes any difference though.
Wish I could help on the ignition harness, not sure, just getting okay with changing fuel,
Old Aug 9, 2005 | 02:04 AM
dodo_croatia's Avatar
jump...
Just yesterday i have put new plugs. Before yesterday my cold starts were a mess, i had to wait for my car to warm up completely, otherwise it would stall, and also car has steady idle. Today morning was 10 'C outside, quite cold, i had no problems with starting the car.
Also, i can feel that the ride is better, much better than stock. I am starting to wonder if my old plugs were not working properly.
New plugs are Denso Iridium Racing (IRT01-34 and IRL01-31), both one heat range colder.
Old Aug 9, 2005 | 09:50 AM
cretinx's Avatar
that's pretty cold for the middle of summer . . . . .
glad to hear plugs seem to be fixing things - they're a lot easier than buying an ignition harness and tuning that.
Old Aug 9, 2005 | 10:19 AM
MadDog's Avatar
Consiglieri
Unless you are increasing the boost beyond the std. 7psi or so, you shouldn't have to pull timing. I think that's the general consensus. I also have the Denso plugs waiting for my turbo install. You'll have to clean them more often, but I think they are worth it just for insurance.
-MD
Old Aug 9, 2005 | 10:50 AM
r0tor's Avatar
Unless I have missed an announcement somewhere, the standad greddy ignition harnass will still melt your coils unless it is modified to correct the voltage output
Old Aug 9, 2005 | 04:47 PM
jump...
2 cretinx: thats the weather like up on the north, in the morning we have 10 to 30 in the day, down at south we have daily 35+ 'C
btw, does anybody now negative consequences of colder plugs. i have heard that during cold starts it wont start?
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Sheldon24
Sep 21, 2015 04:53 PM
