View Full Version : Grease stain under door handles
Gr8M8
08-06-2005, 08:20 PM
guys,
my 8 is just 4 months old. Recently, while washing the car I've found grease stains (like when water streaks down the door after a wash) under both door handles which are pretty hard to remove - anyone else get this? Never had this before with any other car...
cheers,
John
Revolver
08-06-2005, 09:34 PM
guys,
cheers,
John
Hi John.
The first thing I thought of is that you regularly have people with dirty hands opening the doors leaving a build-up of grease that causes dirty streaks when the handles cop a flushing while washing the car. Do you notice the grease stains at other times?? :confused:
Otherwise, have you checked to see if the handles have an excessive lube build-up (can't think why that would be)?? :confused:
BTW - I notice you're a good NSW boy - you coming to the Nats? Please post on the NSW owners thread what you're doing. Thanks :)
EZZY
08-07-2005, 12:55 AM
guys,
cheers,
John
you can clean it with grease & wax remover (you can get a small tin form supercheap/repco etc) and clean soft cloth.
wipe them clean, then give it a polish to restore the shine afterwards.
Gr8M8
08-07-2005, 05:30 AM
thanks Revolver and ezzy for your replies - no don't have people with dirty hands getting into the car and it's on both sides. I'll try and get it off with the grease remover and see how I go. Just wanted to see whether it was a common problem - doesn't seem to be.
cheers boys.
RXE16T
08-07-2005, 09:05 PM
Actually it is a common problem. It occurs as a result of the car not being dried properly following washing.
Gr8M8
08-08-2005, 05:02 PM
Actually it is a common problem. It occurs as a result of the car not being dried properly following washing.Well I always chammy the car after I wash it...
cheers,
John
EZZY
08-09-2005, 03:56 AM
cheers,
John
and 9 out of 10 times i would run the air compresser blower throught the gaps/seals to remove water :p
Wildcard
08-09-2005, 04:54 AM
Can't say I've had this problem....
Or perhaps I am not looking hard enough?
