Question about installation of revi and ram air duct.
Old Aug 4, 2005 | 01:38 PM
oryas's Avatar
I was planning on buying and installing the Ram Air Duct first. Later on when I can afford it or when it's carb certified, purchase the Revi. I know I have to remove the nose of the car to install the Ram air Duct. Would I have to remove the nose of the car again when I install the Revi? Or can I circumvent this since I already removed the nose once for the Ram Air Duct?
Old Aug 4, 2005 | 01:57 PM
zoom44's Avatar
you would still need to remove the nose. you will also have to remove the ram duct and re intsall it.
Old Aug 4, 2005 | 02:37 PM
Hou-TX-RX-8's Avatar
^^Is correct there is a nut on the inside of the RevI that has to be tightened by putting your hand in from the front. I wonder though if you put the Ram Air Duct on and remove the VFAD stuff, you may be able to get to that inside bold from the engine bay side of the intake box. and install the REVI without taking off the front bumper twice.
Old Aug 4, 2005 | 02:49 PM
zoom44's Avatar
well i suppose you could take the filter out and install the revi that way reaching thru the filter space
Billy Marcial
Mar 1, 2018 06:50 AM
8is>enuff
Sep 24, 2015 08:57 AM
8is>enuff
NE For Sale/Wanted
Sep 3, 2015 07:57 PM
RXeckless
Aug 16, 2015 12:51 PM
MolecularConcept
Aug 5, 2015 04:43 PM
