Top speed with FI
Old Aug 4, 2005 | 08:09 AM
X-MAN S's Avatar
Top speed with FI
What is the fastest you FI guys have gone in a RX-8? Although I don't condone triple digit speeding, I realize that people want to test the limits of their purchase.
Old Aug 4, 2005 | 11:16 AM
brightnova's Avatar
Rampage!!! Arghh!!!
On the track of course
Old Aug 4, 2005 | 11:28 AM
moRotorMotor's Avatar
Rotary eXperimental-8
Is there something I'm missing? This car is governed at 140 mph. How would having forced induction change the top speed on this car?
Old Aug 4, 2005 | 11:29 AM
ZGlide's Avatar
it's governed at 140mph? my speed governor must be broken then......
Old Aug 4, 2005 | 11:35 AM
Nemesis8's Avatar
Bigus Rotus
We went over 148 on the dyno in NA form
Old Aug 4, 2005 | 11:44 AM
So that means this car isn't governed?
Old Aug 4, 2005 | 11:47 AM
Nemesis8's Avatar
Bigus Rotus
Look for the second clicky
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/pics-vids-dyno-day-53949/
Old Aug 4, 2005 | 11:50 AM
Gambit's Avatar
Screw gas mileage
I think they way they did the governing was the RPM's are limited in fifth gear
Old Aug 4, 2005 | 11:52 AM
Nemesis8's Avatar
Bigus Rotus
That was a fifth gear pull to 9,500 RPM @ 184 MPH in the video
Old Aug 4, 2005 | 12:20 PM
What would it do in 6th gear?
Old Aug 4, 2005 | 01:39 PM
khtm's Avatar
I like rusty spoons
Definitely not. I've done 240 kph = 149 mph on a track.
The problem with the top speed is unless you're going down hill, the engine isn't powerful enough to push the car any further.
With a turbo it should be...I'm also curious as to the original poster's question.
Old Aug 4, 2005 | 02:31 PM
Hou-TX-RX-8's Avatar
I imagine you should be able to go faster with FI it will help with the aerodynamic drag that you need to overcome by giving you more power, hence allowing you to go faster.
Old Aug 4, 2005 | 02:48 PM
DreamWarrior's Avatar
184 in 5th...really.......I've had my car around 130 in 5th and it didn't seem like I had the revs left to hit 184 even if the engine could get the car there.
Old Aug 4, 2005 | 02:56 PM
KYLiquid's Avatar
Oil Injection
I have had the car to 147 on the GPS car was reading 150 if i rember right. the car feels like it should be able to top out 5th gear around 155-160ish area.
I think if you were to shift to 6th you would lose speed.
Old Aug 4, 2005 | 03:14 PM
lurch519's Avatar
www.evoperform.com
unless they had the gearing changed, that would be quite impossible, as 80 mph in 6th gear is 4000 rpm, that means that 180 in 6th would be right around 9000 rpm.
i believe that was a 6th gear pull to redline
Old Aug 4, 2005 | 03:16 PM
Aseras's Avatar
Well I've gone 167 in my NA 6 speed.... Nice cool florida night 2 am. 6 mile visibilty. nothing in either direction on this road for 25 + miles. started slowing down around 140... started crawling @ 150 and took almost 30 seconds to make 167. IIRC 4th topped out at 137, 5th was 151 and then to 6th shifting around 9000.
Old Aug 4, 2005 | 03:22 PM
Nemesis8's Avatar
Bigus Rotus
That was on a dyno with ZERO wind resistance guys
It was fifth gear - I was there.
Old Aug 4, 2005 | 03:45 PM
khtm's Avatar
I like rusty spoons
That's complete BS.
Redline in 5th gear is 227 KPH = 141 MPH. Trust me.
Old Aug 4, 2005 | 03:47 PM
khtm's Avatar
I like rusty spoons
I don't know what kind of crack you guys are smoking, but I've redlined 5th gear at 141 mph. I guess it could have gone a bit faster since I didn't hit fuel cutoff but there was definitely a BEEP.
Regardless, 184 mph is ONLY attainable in 6th gear.
Old Aug 4, 2005 | 04:05 PM
lurch519's Avatar
www.evoperform.com
^^absolutely, wind resistance has ZERO effect on gear ratios.
Old Aug 4, 2005 | 04:13 PM
alnielsen's Avatar
There could be a difference in tire sizes accounting for the difference.
Old Aug 4, 2005 | 04:17 PM
ktrian25's Avatar
149 mph on the way to vegas from la
149 mph on the way to vegas from la at 4:30 am
Old Aug 4, 2005 | 04:21 PM
lurch519's Avatar
www.evoperform.com
different tire sizes will make a difference in the ACTUAL speed of the car, but the speed we are discussing is the actual speedometer reading, which is derived from the drive train of the rx-8 before the tires.
Old Aug 4, 2005 | 04:28 PM
Nemesis8's Avatar
Bigus Rotus
Oops, that might have been a 6th gear pull. There is another clicky that showed 152 MPH in fifth. Sorry about that...
Look for this one: rx8_5thgeardyno.wmv
Old Aug 4, 2005 | 06:38 PM
Aseras's Avatar
You guys are talking about DMP's Dyno? it did 152 in 5th and 184 in 6th.
