Key(/fob) coding didn't work!
Old Aug 2, 2005 | 01:51 PM
RX8SpdDmn's Avatar
I got a switchblade key from a Mazda MPV (which does NOT have a trunk release). I had a key cut for my RX-8. I popped the little pin out of the key shaft that holds it into the rotating part of the switchblade and I pulled out that key. I scribed the shape of that key onto my newly cut key and then cut it out and shaped it with a Dremel. I reinserted my new key and put the pin back in and the fit is perfect.
I followed the directions I found here: https://www.rx8club.com/series-i-do-yourself-forum-73/diy-code-your-own-key-remote-43873/
Neither my new key, nor the key fob worked after either process. Any ideas as to why??
Old Aug 2, 2005 | 03:08 PM
cleoent's Avatar
n00b
maybe because you;re using a minivan key for your sports car?? lol
What exactly didn't work? YOu have 2 keys and your new one right?
Old Aug 2, 2005 | 10:41 PM
RX8SpdDmn's Avatar
I figured that since my car had 4-doors, I was close enough! :p
Well, the key didn't start the car (the security light flashed at me when I tried), and the fob didn't unlock/lock the doors.
I have 2 original keys, plus the valet (although I wasn't using it). Is there a modification to the process that I'm missing?
Old Aug 2, 2005 | 10:47 PM
Gomez's Avatar
Shifty Bastard.
MPV models do not have an anti-theft ignition system & the key does not contain a transponder. The MPV key is not compatible with the Miata or RX8. Sorry the MPV fob won't work on an RX-8.
Gomez.
Old Aug 2, 2005 | 10:54 PM
Gomez's Avatar
Shifty Bastard.
Part numbers as follows......
FE04-67-5RY, Transmitter for the RX-8.
LF22-67-5RY, Transmitter for the MPV (W/Pwr Sliding Doors)
LF20-67-5RY, Transmitter for the MPV (W/O Pwr Sliding Doors)
Old Aug 3, 2005 | 09:12 AM
RX8SpdDmn's Avatar
damn it.
thanks for the info.
Old Aug 3, 2005 | 09:46 AM
cleoent's Avatar
n00b
dont ya think you could have looked into that before you bought the parts? lol
delicious_dallan
Jan 17, 2020 09:17 AM
uZu
Dec 30, 2015 12:35 PM
Rx808BI
Aug 9, 2015 10:06 AM
Nisaja
Aug 6, 2015 01:27 AM
Bomba
Jul 22, 2015 06:46 AM
