idling problem due knn typhoon intake
Old Jul 28, 2005 | 11:20 PM
jetblast's Avatar
vroom vroom
gdday bros
can anyone help me with the above mentioned?
i've had the typhoon for close to 4 months without any problem till 2 weeks ago.
my idling fluctuates a little at times.
if i put my gear to neutral and roll to a stop at the lights, sometimes the engine dies off but can be restarted immediately with no problem.
i've a delfi oil pressure gauge onboard and when i'm waiting at kerb side the oil pressure fluctuates a little too, moving a few units with no increase in throttle.
can anyone shed some light on this.
many thanks.
Old Jul 28, 2005 | 11:30 PM
Joz's Avatar
Joz
Have you tried cleaning your MAF (Mass Airflow Sensor)? It is in the rubber connector between the original airbox and the butterfly valve in the intake system. My idle was 'drifting' at times and while it never stalled, it was annoying. Removing the two screws (don't need to remove the wiring harness) which mount the unit into the rubber 'hose' (about 3 inches in diameter), slide it straight up, blast with carb cleaner then compressed air to clean it all out has worked great. But maybe I've just ruined the MAF and don't know it yet. Its been over a week and the idle has been stable since cleaning the MAF.
Old Jul 29, 2005 | 10:53 AM
Frank Patrick's Avatar
KN system/MAF
No question the MAF gets dirtier with the more direct airflow the KN provides. It's really no issue a few squirts of intake cleaner doesn't clear up right away. A good preventive measure is once every 5K.
Old Jul 29, 2005 | 10:59 AM
zoom44's Avatar
it gets diritier due to the oil on the filter as well. closing this thread as he has another in the issues and problems section
xAgyex
Jun 3, 2026 03:47 PM
ladnarf1
Apr 29, 2021 11:53 PM
dmengel
Feb 16, 2016 09:47 PM
talonhart2
Aug 26, 2015 04:14 PM
dancingdan42
Aug 19, 2015 09:29 AM
