Slick50 (and other additives) for the Rensis?
Old Jul 28, 2005 | 09:08 PM
RVM's Avatar
RVM
go away and die
Good, bad or neither? I found that Slick50 made a very noticeable impact on the performance/smoothness/efficiency of my '96 Ranger, but that's an I4. Is the teflon in additives such as Slick50 beneficial for the Renesis? Are any additives at all beneficial/detrimental?
Old Jul 28, 2005 | 09:45 PM
therm8's Avatar
Bummed, but bring on OU!
I'd say some additives are beneficial. I personally use Yamaha Ring-free, to prevent carbon build-up (the rotary's nemesis), along with a few healthy redlines per day. I don't know anything about Slick50 though.
Old Jul 28, 2005 | 09:51 PM
cowboyup75146's Avatar
Cool what type of oil to use
What type of oil do you use when you have to add some in between oil changes
5w 30 penzsoil , castrol, quaker state??????????
Old Jul 29, 2005 | 06:09 AM
expo1's Avatar
He's as bad as Can
Has something changed with the way they make Slick 50???
"According to the FTC complaint, the companies’ claims that without Slick 50 auto engines generally have little or no protection from wear at start-up and commonly experience premature engine failure caused by wear were false."
http://www.ftc.gov/opa/1997/12/petapp62.97.htm
Old Jul 29, 2005 | 08:26 AM
alnielsen's Avatar
There a so few moving parts in a rotory engine that I don't see any advantages to using a friction reducing additive to the oil. It would however increase the longevity of what parts it does come in contact with.
Old Jul 29, 2005 | 03:04 PM
beachdog's Avatar
There has never been any proof that the Teflon in Slick 50 did anything at all. There were even complaints of the product clogging oil passages. Even Dupont, the supplier of the Telflon, went on record as stating in order for Teflon to permanently coat metal, it needs to be applied in accordance with their application instructions. Floating around in the oil did not meet their application process.
Save your money.
Old Jul 29, 2005 | 04:01 PM
cgrx's Avatar
DRIVEN
might have to pick some of that up
Old Jul 29, 2005 | 04:53 PM
Dark8's Avatar
Ride Naked!
Isn't that (Yamaha Ring-free) a fuel additive used in marine engines? If so, what does it cost you a tank to use it?
Edit: I found it: http://www.yamaha-motor.com/outboard...46/detail.aspx
Old Jul 29, 2005 | 07:26 PM
RVM's Avatar
RVM
go away and die
Hmm well, maybe Slick50 was doing something else to my Ranger then. ^^
How well is the Yamaha stuff working for you? How often do you add it?
Old Jul 30, 2005 | 12:52 AM
HD-Paschke's Avatar
http://www.ftc.gov/opa/2000/03/motor.htm
http://skepdic.com/slick50.html
Old Jul 30, 2005 | 08:30 PM
RVM's Avatar
RVM
go away and die
Great links, thanks! Must have been the oil change itself that led to the improved smoothness. I hate being misled!
Anyone else have word on that Yamaha stuff?
Old Aug 2, 2005 | 11:49 AM
fullsmoke's Avatar
Anatomy of a corner...
I personally use Castrol GTX. I've used it in all 3 of my RX7s. However, why are you using 5W-30? Is it rediculously hot over there?
One addative I use is MMO (Marval Mystery Oil). You'll hear RX7 fans swear to this stuff (www.rx7club.com). Add to gas, add to oil, pour a lil down the carb (if it's carb'd). I've only used MMO in my RX7s though, not in the 8. I did notice that a few oil changes with MMO and the oil did come out a little cleaner. Also, the idle and coasting was slightly smoother (this is on a rotary with around 200kmiles).
FS
Old Aug 2, 2005 | 12:36 PM
KYLiquid's Avatar
Oil Injection
i change the oil and filter every 3k miles with Castrol GTX and use 2oz of Lucas Fuel System Treatment (1 gal for $22 at Advanced Auto Parts) everytime I fill up. I also only fill up with Chevron 93 or Shell 93 (they are both 'Top Teir' but I find the Chevron gives me better mpg by about 2mpg
Always letting the car warmup before you get on it and cool down after you get on it along with regular oil changes and other matinence will give you great life/performance out of this engine. Oh and make sure you redline it it often :-) I top out the first 3 gears at least once everytime I run the car.
ShellDude
Oct 1, 2015 09:55 PM
DVerdeyen
Sep 13, 2015 11:19 AM
RAE008
Sep 12, 2015 09:08 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
