Removing the Cat and Installing a Straight Pipe
Old Jul 25, 2005 | 11:35 AM
morganoh's Avatar
Any one has remove the Cat Converter and install a straight pipe on the mid part of the exhaust system?
I was quote $80 for a custom made straight pipe (screw in and removable)
The original cat pipe can be install back during inspection.
Do the straight pipe give a few more HP to the car and will it do any good or harm to the car.
Please advice
Old Jul 25, 2005 | 11:45 AM
lennon's Avatar
Remove mid pipe will definitely cause engine vibrates a lot during idling, low-end torque will diappear as you might find your car is harder to launch. However, exhaust will sounded better and better response in high speed. Typical straight pipe is more suitable for turbos. Not to forget fuel comsumption will go up too. But for $80, you should have a go to prove me wrong!
cheers
Old Jul 25, 2005 | 01:43 PM
morganoh's Avatar
cheers
Does it means that Low end torque need back pressure from the Cat ?
I thought with lesser resistance in the exhaust will give a better fuel consumption? how does it actually works?
Old Jul 25, 2005 | 06:48 PM
cuscorex's Avatar
爆 走 RE风 林 火 山
yes,the bk-pressure might b lost,but u got a more fast-flowin on the high.another ting to note,if u r runnin w/o the CO sensor,the 'chk engine' light wil lit.
Old Jul 26, 2005 | 12:43 AM
morganoh's Avatar
Anyone try removing the cat before? Cos would like to seek for his/her experience before doing it myself.
Old Jul 26, 2005 | 01:02 AM
EBS's Avatar
EBS
1. To elaborate what bro Cuscorex say, most cat has O2 sensors and some other sensors to monitor the flow and feedback to ECU for optimal driving. Without the sensors, the CEL light up (check engine light) telling u ECU sense a prob. Some car, after prolong CEL will stop working and have to get the ECU reset.
2. U definitely lost low end torque but mid/high will be free revving. Damn shiok and good for track as u are always on high rpm.
3. Does the major tuner make such replacement cat pipes? If yes, buy from them (typically around 15000 to 20,000 Yen). For direct fit type, they have all the necessary holes for the sensors.
Enjoy
Old Jul 26, 2005 | 01:22 AM
morganoh's Avatar
Enjoy
The company that quote me $80 is Man Exhaust in Sin Ming Insdustrial Estate.
There's alot of cars modifying their cars everyday. including Audi and Pos as well.
I do not know if they know what they are doing, cos neither do I.
Old Jul 26, 2005 | 07:24 AM
EBS's Avatar
EBS
Flip thru the Hyper Rev magazine. The straight thru racing section (pipe) is just a plain straight pipe replacing the stock Cat. A properly designed one will fit the Cat portion exactly and has the necessary holes for the sensors to screw in. U just need to take out the stock Cat, replace it with the pipe, plug in the sensors and finished.
Man exos 'specialized' in doing exos mods. I'm not sure of their workmanship cos never tried them be4. Those Jap ones are real nice. An alternative is to operate ur mufflers as this is not too obvious as removing the Cat. Man can do those as well.
Old Jul 28, 2005 | 06:08 AM
foo77's Avatar
4th batch : Apr 03'
my advice is don't do it, you'll regret for it
Old Jul 28, 2005 | 07:45 AM
sqflyer's Avatar
Heavy Machinery Operator
Bro... a friend of mine removed his cat, CEL came on and lost of low end torque. In the end, he replaced the cat. If you drive at high RPM most of the time or track a lot, then it might be useful, but for daily driving the loss of low end torque is just going to increase your fuel consumption. A couple of other points, the exhaust will sound funny after you replace the cat with a straight pipe, can hear a slightly higher pitch flappy sound like a 2-stroke motorcycle. Also the exhaust smell is very obvious without a cat. If you ever get pulled over by TP, they can definitely "smell a rat" and might decide to impound your car for inspection. If you wanna change your cat, I think it's better to get a high-flow or racing cat as opposed to removing your cat completely.
Old Jul 28, 2005 | 07:56 AM
Vanquish's Avatar
That's it! I got one less mod on my mod-list! :D :D :D
Old Jul 28, 2005 | 08:19 AM
EBS's Avatar
EBS
Yes. Think better to try other mod first :D
Old Jul 28, 2005 | 10:32 AM
morganoh's Avatar
Guess this Car is very special .
Cos most of the normal 1.6-2L cars . power got even better without the cat.
Billy Marcial
Mar 1, 2018 06:50 AM
jay_tibo
22
Sep 13, 2016 08:10 PM
Kanthinar
Dec 21, 2015 01:24 PM
Jvswan
28
Jul 23, 2015 09:02 AM
