Engine number
Old Jul 24, 2005 | 07:10 AM
Spider's Avatar
Engine number
Would anyone be able to tell me where the engine number is located on the RX8 please?
I've go the intake off and the alternator out and I haven't been able to spot it yet. Is it on the cover, rotor housings or end plates?
thanks
Andrew
Old Jul 24, 2005 | 08:00 AM
Go48's Avatar
thanks
Andrew
Owners manual page 10-3.
Old Jul 26, 2005 | 07:16 AM
Spider's Avatar
Thanks Go48 for responding.
I frequent this site because I'm building a tube frame sports car with a RX8 engine so I didn't have a owners manual.
Good news is that it can be downloaded.
To me the diagram appears to be refering to the space next to the 13B of the front rotor housing (the alloy bit). In my case there is no number there.
I can find a number on the top of the front plate on the plug side.
Its a 5 character code 4 numeric and one alfa in the format 9999A.
Could anyone confirm if that looks like a engine number format to them?
thank you
Andrew
Old Jul 26, 2005 | 07:43 AM
Go48's Avatar
thank you
Andrew
On my '04 RX-8 the engine number is just above the trailing plug on rotor housing #1. It is a 6-digit, numeric number, no alpha characters, followed by a dashed line. It's in the same place as "13B MAZDA" and the number is to the right of "13B". If this is a "replacement" engine, maybe the format is different from an OEM-installed engine??
What series/events are you going to run the car in? Sounds interesting.
Old Jul 26, 2005 | 07:44 AM
missinmahseven's Avatar
Glitchy Rotary Madness
Stand on the driver's side of the engine, so the driveshaft is to your right and the fans to your left. Find the dipstiock. Go left about 4 inches. You should find a marking like this: "mazda 13B xxxxxxxx" where xxxxxxxx is your number.
Old Jul 28, 2005 | 08:02 AM
Spider's Avatar
Thank you to everyone for responding.
Hopefully some circuit super sprint Go48.
Its definately not next to the 13B. I believe the engine is an early one ex factory.
The numbers on the front plate are the traditional characters made from dots like a needle point. I'd have to assume this is the identifying mark. If it wasn't unique it would be included in the casting and you wouldn't go to that effort.
regards
Andrew
Old Jul 28, 2005 | 11:06 AM
JonsToy's Avatar
Registered Rep
My dealer ran me a Warranty Vehicle Inquiry Detail when I took my used 8 in for warranty service. Among other things, the report lists the engine number.
Old Jul 29, 2005 | 04:36 AM
Spider's Avatar
mr. GrandGame
Sep 9, 2025 10:41 PM
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
vapor2
Nov 3, 2020 03:38 PM
Pelleilee
Sep 29, 2019 10:07 AM
