Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Need Help From Austin Peeps
Old Jul 21, 2005 | 09:23 AM
dazygirl415's Avatar
Exclamation Need Help From Austin Peeps
Can someone give me directions from I35 or a map of how to get to Lime Creek? I found 1431 but that's it and I remember driving both back in April. Thanks in advance!!
Old Jul 21, 2005 | 09:53 AM
canaryrx8's Avatar
If you take 620, it will take you right to where everyone was back in April. It's ben a while but from what I remember 620 ends in Round Rock (or begins for that matter). So if you're coming in on 35 from Dallas it's going to be on the left and you should see an exit for it. That might not be the best way however, let me think on this a little longer and get back to ya'
Old Jul 21, 2005 | 10:10 AM
Thanks Canary.
Old Jul 21, 2005 | 12:36 PM
canaryrx8's Avatar
These are directions from Round Rock, should give you a general idea and from looking you can probably determine a better way if necessary.
http://www.mapquest.com/directions/m...2s=Tx&2z=78641
Old Jul 21, 2005 | 12:46 PM
You are the best!! Thank you!
Old Jul 21, 2005 | 02:01 PM
Rez's Avatar
Rez
There is a new section of road near the northern end of Lime Creek that can be confusing if you are used to the old layout. Watch carefully for the right hand turn (assuming you are coming from 1431) to keep you on Lime Creek. Or simply come at it from the other end - take 620 south and watch for the turn for Volente, follow that winding road (also a fun road) all the was past Volente Beach and then make a right onto Lime Creek.
Old Jul 21, 2005 | 02:03 PM
I marked down 2222 from 35, taking a left onto Lime Creek. Will that work? I'm trying to keep the number of highway interchanges to a minimum since this is only the second time I've been in the area. I'm going to be in the mood for driving, not getting lost.
Old Jul 21, 2005 | 02:21 PM
Rez's Avatar
Rez
2222 is a fun road on it's own and will come out on 620. I you go straight across 620 you can follow Bullick Hollow Road to 2769 (aka Cypress Creek Road), make a left and then end up at the South end of Lime Creek by Volente Beach.
See <http://maps.google.com/maps?q=austin,+tx&ll=30.431210,-97.889042&spn=0.090554,.124592&hl=en> and <http://maps.google.com/maps?q=austin,+tx&ll=30.452262,-97.907925&spn=0.022634,0.031148&hl=en> for a better idea of the directions.
Old Jul 21, 2005 | 02:52 PM
canaryrx8's Avatar
yup, that sounds like a cool way to go, there is some construction where Koenig (aka 2222) crosses over N Lamar but after that it is smooth sailing, be sure to go right instead of left after you pass underneath Mopac on 2222/Koenig as well
If for some odd reason you do get lost I can assist via cell if you need it, just let me know
Old Jul 21, 2005 | 03:11 PM
I'm so glad you mentioned that!! I remember driving it now that I think about it, but I had completely forgotten!!!
JAYDOH
Sep 24, 2015 01:54 PM
PhineasFellOff
57
May 11, 2004 08:20 AM
Skapunk
Gulf RX-8 Forum
12
Mar 5, 2004 05:18 PM
DrKillJoY
Gulf RX-8 Forum
Mar 15, 2003 11:39 AM
