View Full Version : 3-rotor Renesis Engine Question
Mazinkaiser1001
07-20-2005, 11:43 AM
Hi, I am currently doing a research paper on rotary engines. Is it possible to custom-build a 3-rotor Renesis Rotary Engine, to make a rough Renesis equivalent of the 20B-REW? As I see it. rotary engines seem pretty modular and easy to mod, it looks like a matter of simply stacking rotors on top of each other. I need to make sure though, and please correct me if I am wrong.
Thanks in advance!
expo1
07-20-2005, 11:51 AM
You must not have been reading many threads on this board; the RX-8 is not an easy car mod. The big issue is the motors ECU. BUT you can custom build almost anything with enough money, time & expertise. In this case about $20,000-$40,000.
Nemesis8
07-20-2005, 11:55 AM
I'm not 100% sure about this, but not with the side exhaust port on the Renesis. If this engine had peripheral exhaust ports, then maybe.
Mazinkaiser1001
07-20-2005, 12:10 PM
So it can't be done? I was under the impression that it is possible to build a 3-rotor Renesis engine, even with the side exhaust port. For the matter, I was wondering if it's possible to combine two Renesis 13Bs together to make a 4-rotor monster like the R26B.
expo1
07-20-2005, 12:22 PM
Again if you have enough MONEY it can be done. You will need to re-engineer most of the car. The placement of the motor was designed for the 13B. Put in a 20B and you have to redo the engine mounts, steering, suspension. Plus build a custom exhaust, ECU, cooling & intake system. Sure it can be done, but it’s not like adding a slice of bread to a ham sandwich to make it into a Club. It would be "a little" easier to put in an older “pre Renesis” 20B but still a very expensive mod.
zoom44
07-20-2005, 12:54 PM
perhaps doing a search for 3 rotor before starting a thread would have found for you this thread http://www.rx8club.com/showthread.php?t=66636 which was just started 3 days ago and had posts yesterday. read that one and direct your questions there. this thread is closed
Dark8
07-20-2005, 01:46 PM
Closed? :p
zoom44
07-20-2005, 02:12 PM
swings the ban stick at dark8 :eek: :D :o
now its closed :D
zoom44
07-20-2005, 02:13 PM
waves the ban stick in the general direction of dark8 :eek: :D :o
now its closed :D
wedge357
07-20-2005, 02:24 PM
now its closed :D
HUH???
zoom44
07-20-2005, 02:56 PM
w the hell? ok now it is :o :o
