View Full Version : Knock sensor
zoomzoom_8
07-19-2005, 10:06 PM
Does anyone know if there is a way to hack into the stock knock sensor to connect a light or some other indication of when knock is sensed? I have seen other aftermarket knock sensors that do this and was just wondering if ours had that capability already. If not, would an aftermarket knock sensor work for us to help ensure safe tunes?
lurch519
07-19-2005, 10:29 PM
im not sure, but check out hymee's scanalyser, his software should be able to read any parameter that the ecu sees and can display the info on a laptop
StealthTL
07-19-2005, 10:58 PM
Casper electronics makes one, ugly as sin, but might do the job....
S
Link to knock sensor. (https://www.casperselectronics.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=102004&Category_Code=Special)
Razz1
07-20-2005, 12:42 AM
I wish someone would post a DYI on this, as I believe if you get rid of the sensors our cars would be faster. The sensors we have are too sensative and retard the timing when our car isn't knocking.
zoomzoom_8
07-20-2005, 01:24 AM
So does anyone know if this actually connects into the stock knock sensor or total standalone. Yea, it is ugly as sin, looks like it feel out of the ugly tree :) Hymees scanalyser doesnot sense the knock sensor or if it does I can not figure out how to do it. That would be great, if it did though.
sco
07-20-2005, 03:32 AM
Knock Retard is a Mazda Proprietary parameter we'll be able to retrieve in the version I'm currently working on. It doesn't give you a knock count -- it tells you if the PCM has retarded timing due to knock.
r0tor
07-20-2005, 08:21 AM
the rx8 extended data software for the canscan will do it
zoomzoom_8
07-20-2005, 11:29 AM
How soon do you think you guys will have the new version out? How will the upgrade work with current users? Thanks!
Chris
zoomzoom_8
07-20-2005, 11:31 AM
Chris
oh, and if the 8 ecu cannot retard timing and prevent knock, would we be able to tell that and know that she is knocking? Thanks
Chris
