??? Turbo PSI
Old Jul 19, 2005 | 10:29 AM
Velocity Rx8's Avatar
Question ??? Turbo PSI
Hello every one im planning on getting the greddy Turbo kit but i want to know how to reach higher psi on the turbo . I know a lot about rotary but im not the best with turbo. so if u guys can tell me how to help the psi go higher couse i seen a Rx8 with 4 psi and it was running better than stock but wasnt as good as i expected . im looking to hit 6 psi so if any one can help out thanks.
Old Jul 19, 2005 | 04:48 PM
zoomzoom_8's Avatar
you will peak around 6 psi on the stock greddy turbo but only for a few seconds, most boost hangs around 4ish to 5ish. adjust the wastegate acatator screw and you can up it to around seven i have heard. after that boost controller but not over 9 psi without upgraded injectors
Old Jul 19, 2005 | 07:30 PM
Fanman's Avatar
7.5 psi on a stock Greddy kit (tuned), going to 8 psi., drops of to about 6 at high revs.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Michael Bryant
Oct 12, 2015 03:07 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
