View Full Version : New Mazda Recall?
djseto 07-18-2005, 05:37 PM Found this on the National Highway Traffic Safety Admin webpage:
make : MAZDA Model : RX8 Year : 2004
Manufacturer : MAZDA NORTH AMERICAN OPERATIONS
NHTSA CAMPAIGN ID Number : 05V317000 Recall Date : JUL 07, 2005
Component: ENGINE AND ENGINE COOLING
Potential Number Of Units Affected : 56000
Summary:
IF CERTAIN PASSENGER VEHICLES ARE PARKED AND THE ENGINE IS OPERATED AT HIGH RPM'S FOR AN EXCESSIVE LENGTH OF TIME, SOME OF THE PARTS AROUND THE EXHAUST SYSTEM CAN MELT AND PRODUCE A VARIETY OF MALFUNCTIONS. PROBLEMS CAUSED BY THE EXCESSIVE HEAT BUILD-UP CAN RANGE FROM INOPERATIVE OXYGEN SENSOR, NEUTRAL SWITCH AND BACK UP LIGHTS, PROBLEMS WITH THE PARKING BRAKES, MALFUNCTIONS OF THE GAS GAUGE AND/OR POSSIBLE FUEL LEAKS RESULTING FROM HEAT DAMAGE TO THE FUEL TANK.
Consequence:
FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
Remedy:
DEALERS WILL INSPECT AND REPLACE PARTS. THE RECALL IS EXPECTED TO BEGIN DURING AUGUST 2005. OWNERS SHOULD CONTACT MAZDA AT 1-800-222-5500.
Notes:
MAZDA RECALL NO. 3305G. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
ZoomZoomH 07-18-2005, 05:41 PM come on man, at least browse through the issues & problems section a bit :p :
http://www.rx8club.com/showthread.php?t=66002
well i guess this makes it official, now that it's on NHTSA database :o
beachdog 07-18-2005, 06:39 PM 56000 = potential number of units affected
Isn't that the total worldwide production number since the beginning?
No, Mazda has produced over 100,000 RX8s...
djseto 07-18-2005, 07:19 PM I also found these two. I got my car in November 2004, so should I assume my car has been fixed if my car was affected by these two recalls?:
Make : MAZDA Model : RX8 Year : 2004
NHTSA CAMPAIGN ID Number : 04V075000 Recall Date : FEB 16, 2004
Component: POWER TRAIN:MANUAL TRANSMISSION
Potential Number Of Units Affected : 12000
Summary:
ON CERTAIN PASSENGER VEHICLES WITH MANUAL TRANSMISSIONS, THE HEAT INSULATOR MAY BE CRACKED CAUSING ABNORMAL NOISE.
Consequence:
CONTINUED OPERATION OF THE VEHICLE CAN CAUSE THE INSULATOR TO COME OFF AND COULD POSE A HAZARD TO FOLLOWING VEHICLES.
Remedy:
DEALERS WILL REPLACE THE HEAT INSULATOR. THE RECALL BEGAN MARCH 5, 2004. OWNERS SHOULD CONTACT MAZDA AT 1-800-222-5500.
Notes:
MAZDA RECALL NO. 1704B. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
NHTSA CAMPAIGN ID Number : 04V074000 Recall Date : FEB 16, 2004
Component: AIR BAGS:FRONTAL
Potential Number Of Units Affected : 29300
Summary:
AS A RESULT OF AN NCAP TEST, CERTAIN PASSENGER VEHICLES ARE BEING RECALLED FOR IMPROPERLY WIRED FRONT PASSENGER SEAT AIR BAGS.
Consequence:
THE AIR BAG WILL NOT PROVIDE ADEQUATE PROTECTION WHEN THE VEHICLE IS INVOLVED IN A FRONTAL CRASH.
Remedy:
DEALERS WILL INSTALL A NEW WIRING HARNESS IN THE FRONT PASSENGER SEAT AIR BAG SYSTEM. THE RECALL BEGAN MARCH 5, 2004. OWNERS SHOULD CONTACT MAZDA AT 1-800-222-5500.
Notes:
MAZDA RECALL NO. 1604B-B. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Don't assume that the other recalls have been performed.
At a local meet last summer, I looked under the hood of a car that was manufactured in August of '03, purchased in May of '04, and neither of the recalls had been performed according to the owner nor had he been reflashed to M. His VIN was right next to mine, which is why I know that he should have been covered, but there were no stickeres under the hood, nor did the tap test work to show an M flash. If I were you, I would check under your hood for the stickers telling you that the work has been performed or get it done.
Also, check the Owners section of the Official Mazda web-site, which should show you whether your car has recalls that are pending and have not been performed.
beachdog 07-18-2005, 10:46 PM there were no stickeres under the hood, ...If I were you, I would check under your hood for the stickers telling you that the work has been performed or get it done.
Stickers under the hood are meaningless. Not every dealer installs them after doing the work. Go to a dealer and have them run the VIN through the computer. That will tell if the recalls were performed and any other warranty and service work.
Nemesis8 07-18-2005, 11:15 PM Consequence:
Reminds me of that Hawaii car on fire :eek:
Actually, the stickers aren't meaningless. If they are there, then you can pretty much assume that the work was done. If they aren't there, then he should take the car in and have it checked and check on the Mazda website, which is exactly what I told the guy last year to do, and what this guy should do too. I am just pointing out that he should not assume that the work was already done in the same way that my friend last year should not have assumed that his car had been reflashed just because it was supposed to have been.
army_rx8 07-19-2005, 10:46 AM come on man, at least browse through the issues & problems section a bit :p :
haha seriously..i think our cars are going to explode b/c everyday there is abotu 5 new recalls....oh wait no there isn't people just keep posting the same thing over and over again :p
zoom44 07-19-2005, 12:08 PM yes there are threads abotu the airbag harness and tranny dampner as well as the newest one. no need for new threads about them
