Which exhaust is bigger?
Old Jul 18, 2005 | 01:41 AM
zoomzoom_8's Avatar
ON racinging beat's site, it says 3 inches outside diameter, greddy says their sp2 is 60 mm but does not say whether they measured inside diameter or outside diameter.
Does anyone which one is bigger by inside diameter?
Chris
Old Jul 18, 2005 | 06:48 AM
expo1's Avatar
He's as bad as Can
Greddy is the biggest tips out there. The below thead has photos.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/racing-beat-greddy-sp2-question-63714/
Old Jul 18, 2005 | 10:33 AM
tubing is always measured by OD 3" = 76.2mm
3" is overkill on anything other than a high boost turbo setup
Old Jul 18, 2005 | 10:47 AM
zoomzoom_8's Avatar
thanks guys, lschivo and I are having some horse sounds on both of our turboed 8's. We both are running stock cat and RB exhaust but fanman is running the same with no horse sound. We have heard that the exhaust may be causing back pressure and making the horse sound under vacuum when the BOV will not vent. Adnusting the BOv yields no results. So i guess the question should be which exhaust has the least amount of back pressure, i would say . . RB cause overall the pipes are bigger, the tips do not make that much of a difference right?
Old Jul 19, 2005 | 12:31 AM
right the tips do not make a difference.
Except looks.
Old Jul 19, 2005 | 05:51 AM
the tips can be smaller still because you split the flow in two
Old Aug 7, 2005 | 12:27 PM
BigOLundh's Avatar
#1 Legend
Does anybody know the tube diameter for the Mazdaspeed exhaust?
and yes... tips do not matter... just for sound/looks.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
