Pulled my motor out!
Old Jul 17, 2005 | 07:09 PM
Broke_Apex_Seal's Avatar
What a crap job. I am going to re do the set up and will keep all posted on my findings. Here are a few pics!
http://www.nopistons.com/forums/inde...howtopic=53613
Old Jul 17, 2005 | 07:14 PM
cant seem to get the pics uploaded. Here is a hot link sorry guys. This has been my luck as of late.
Old Jul 17, 2005 | 07:20 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Pulling engines is always a PITA. Are you just doing a rebuild or a porting project?
Old Jul 17, 2005 | 07:26 PM
well I busted my face with a breaker bar and have a nice scare on my face. I might be getting a warranted motor but not for sure yet. I am going to port it for sure and maybe lower the compression if there is some room on the rotors to do so.
Old Jul 17, 2005 | 07:28 PM
Gomez's Avatar
Shifty Bastard.
That's bad news mate. Still, you lasted 3 months longer than I had tipped in Brillo's poll :p . You're the first FI RX-8 owner thats blown an engine by my reckoning. Someone else collected the beers...damn!
What happened?
Old Jul 17, 2005 | 07:33 PM
It ran great until I got that stupid dongle update. Oh well live and learn. I might sell the turbo kit. How much do you think it is worth used? 2400 bucks with a greddy type s BOV.
Old Jul 17, 2005 | 07:39 PM
demon's Avatar
I had serious problems pulling my motor out today...did you just unbolt the motor mounts from the side of the motor or detach the entire mount from the frame? I'm having serious trouble detaching the transmission from the motor! The service manual was vague at best. I also busted up my hands and face pretty badly in the process
Old Jul 17, 2005 | 07:46 PM
I supported the motor from up top! I have a lift so it is a little easier than doing it on jack stands. Then remove the mounts completely and support the trans from underneath and slowly raise the engine and shake and pull until it comes free. Also I took off the upper intake manifold to get better view of it all. A load leveler makes it quick work aswell.
Old Jul 17, 2005 | 07:57 PM
guitarjunkie28's Avatar
port hacker
it's easier to pull a motor from an 8 than an fc or fd... everything's clean
Old Jul 17, 2005 | 08:03 PM
demon's Avatar
Thanks, I'll give it a shot! I guess I just had a bad day, I never had this much trouble pulling an FD motor
Well I worked for Peter Farrell Supercars and worked on FD's for a living so it became "another day at the office" getting motors out so to me it was a little harder but it was my first time. But after a few I can see it being just as easy if not easier.
Old Jul 17, 2005 | 10:03 PM
port hacker
it has a lot more "modular" feel to it.
--pop out the air box, battery, front items
--get rid of the upper manifold so you can reach things
--all the tranny-to-motor bolts can be removed from underneath (this is where that extra $100 in universals and swivels comes in handy )
-- unplug the harness from the ecu
-- off with the wheels-----unbolt the motor mounts fromt he engine and loosten them from the frame.
-- easier to pull it if you remove the exhaust manifold from the engine (i even leave it connected to the midpipe)
--out with the smog pump, acv thing, misc crap from the engine compartment
-- jack up the tranny so it's very close to the top of the tunnel and hook up your cherry picker
give it a few pumps and a few bounces and it'll come right out.
anything i forgot, sorry...just fill in the blanks.
job takes me about 2 hours with air tools.
Old Jul 17, 2005 | 10:05 PM
smrx8's Avatar
how much boost were you running that it blew up ????
Old Jul 17, 2005 | 10:06 PM
port hacker
oh yea...
get a set of reversable gear wrenches.
the 10 is good for the 2 bolts to the upper manifold by the oil filler
the 12 is schweet for the a/c compressor.
buy swivel extensions. buy cheap swivels if you're poor...you're gonna be using them on mostly 6X1.00 bolts.
uhhhhh.....that's it for now
Old Jul 17, 2005 | 10:22 PM
demon's Avatar
Thanks, I had pretty much everything off the car but ended up busting my hand on cherry picker while using breaker bar on a motor mount bolt
Will attack it again soon!
Edit: do you need to take the driveshaft out to give enough room to pop the engine loose without hitting the steering rack?
Old Jul 17, 2005 | 11:23 PM
port hacker
nope
Old Jul 17, 2005 | 11:35 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
I say you drop a 20b in there. lol
Old Jul 18, 2005 | 12:21 AM
port hacker
naw, a cosmo 13b with a gt35r
the shitty thing about popping a seal on a renesis is it has nowhere to go... yea, it'll find its way out eventually, but you're almost guranteed a rotor and housing replacement when it pops.
Old Jul 18, 2005 | 04:49 PM
demon's Avatar
Great idea
Attached Thumbnails Pulled my motor out!-dsc00013.jpg   Pulled my motor out!-dsc00010.jpg
Old Jul 18, 2005 | 05:14 PM
army_rx8's Avatar
X-Sapper
cooooooooooooooooooooooooooooooooooooooooooooooooo l
Old Jul 18, 2005 | 11:49 PM
port hacker
Originally Posted by demon
Great idea
BWAHAHAHAHAHAHAAAAA!!!
and here i thought i was gonna be the first to do something like that :p
props bro!
Old Jul 19, 2005 | 06:28 AM
smrx8's Avatar
Great idea
wow could that really fit ??? what would you use as a computer
Old Jul 19, 2005 | 11:02 AM
zoom44's Avatar
well i know a certain dealer service guy in texas that is replacing alot of engines - he is lifting the car and dropping the motor out from below. hes done like a dozen this way.
Old Jul 19, 2005 | 11:39 AM
MadDog's Avatar
Consiglieri
One dealer has already replace a DOZEN MOTORS???!!!
What's causing so many engine failures in Texas?!
Old Jul 19, 2005 | 11:42 AM
guy321's Avatar
Humpin legs and takin nam
Everything's bigger in Texas.
(real answer:heat)
