Cold idling problem
Old Jul 17, 2005 | 04:58 PM
Lock & Load's Avatar
Cold idling problem
cold start problem
In the last 2 days i have got a surge between 1500 and 2000rpm .
Normally on a cold start my car revs to 2100 rpm then slowly settles down to 1500 , then to 1200 then down to 900 rpm with no problems .
The last 2 mornings i am seeing a swing between 2100rpm down to 1500 rpm then back up to 2100 rpm it does this several times and then finally settles down .
Theres no rough idling once i take off and car drives smoothly
Any one experience this ?? i have done 42,000km .
Maybe i need new spark plugs ??
bad cat sensor
Bad ignition coils
loose wiring
Any thoughts .
B....free
michael
Old Jul 17, 2005 | 10:52 PM
clydejmuggs's Avatar
does the problem go away when you press the clutch?
If so the "In gear" or neutral switch is sticking. It will cause a rolling idle.
Old Jul 18, 2005 | 01:02 AM
I think this could be it because if i put in reverse straight away it does not cause the rolling idle
Now how do i fix this ???
Worshop manual says for a slow return to idle check following .
.ECT sensor malfunction
The thermostat is stuck open
throttle body malfunction
Air leakage from intake air system .
Eccentric shaft bypass valve stuck open
However i feel youhave found the correct answer to my problem .
B...free
michael
Old Jul 18, 2005 | 01:05 AM
If you will stop the "B..free" for a week I will tell you..
I know the entire story...
Old Jul 18, 2005 | 01:08 AM
ROFLMAO :D
OK how about
B...kind
michael
Old Jul 21, 2005 | 02:42 AM
Gomez's Avatar
Shifty Bastard.
We don't have a starter interlock switch on our six speed cars, Clyde. The Yanks have it...we don't.
Old Aug 1, 2005 | 06:31 PM
So in your learned opinion whats the cause of this problem ??
B...free
michael
Old Aug 1, 2005 | 08:17 PM
The switch on the top left of the tranny has nothing to do with the starter mate..
It tells the PCM if the car is centered in the shift pattern aka..neutral.
Old Aug 1, 2005 | 09:57 PM
So are you going to tell us how to fix this problem or are you going to continue jerking us around .
B...free
michael
Old Aug 1, 2005 | 11:09 PM
zoom44's Avatar
michael they just need to put a new switch in
Old Aug 1, 2005 | 11:17 PM
guy321's Avatar
Humpin legs and takin nam
This thread belongs in the Australian forum :D
Old Aug 1, 2005 | 11:19 PM
Thanks :D
B...free
michael
Old Sep 9, 2005 | 09:46 AM
Yeah thanks i know what the problem is but they havent fixed it yet they dont want to believe me nor spend the money on the switch
I will never buy another 1st or 2nd year production car especially from Mazda as its becoming quite obvious that not enough adequate REAL WORLD testing was done on the RX8 , THE PROBLEMS WE ARE GETTING I EXPECT FROM a Hyundia not from MAZDA
B...free
michael
xAgyex
Jun 3, 2026 03:47 PM
ladnarf1
Apr 29, 2021 11:53 PM
Jaco Greyling
Jan 6, 2019 08:39 AM
PotatoCannon
Sep 6, 2015 11:48 AM
dbarber
Jul 25, 2015 01:34 PM
