Glove Box Problem
Old Jul 15, 2005 | 03:55 PM
Cynic10508's Avatar
Glove Box Problem
If you look on the right side of the glove box there's a peg extending out the side. Around that peg is a plastic piece that is attached to what is most likely a small hydraulic cylinder to help keep the glove box from opening too quickly. I just noticed that the plastic piece connecting the box to the cylinder is broken on my car, causing the glove box to drop open like a rock. Has this happened to anyone else?
Old Jul 15, 2005 | 04:06 PM
brothervoodoo's Avatar
RainMan is Back
Yes, it's happened to a few folks. There was an airbag recall in which you had to get into the glove box. In the recall itself it clearly states to be careful not to damage this part. It even gives a part number should it happen to break. Check Rosethal site for the TSB bulletins, read the the airbag recall...
Old Jul 15, 2005 | 04:15 PM
Cynic10508's Avatar
Well that would explain things. I did take my 8 in for the air bag recall to the same people who replaced my oil and left my dip stick sittin on top of the engine block...
Old Jul 15, 2005 | 04:20 PM
RainMan is Back
BTW, Rosenthal are missing some TSB's. I can't find the Passenger Airbag Recall notice or the Free Maintenance Schedule for early buyers, both used to be there...
Anyway, they probably broke it and should fix the issue under warranty... It would be easier if you have the TSB in hand though.. maybe somebody here saved it?
Old Jul 15, 2005 | 08:06 PM
beachdog's Avatar
I don't have the entire TSB, just the page that showed the warning. I will mail it to you.
Old Jul 15, 2005 | 11:41 PM
gr8jab's Avatar
I can tell you exactly how it happens... If you close the glove box without re-attaching the gas strut you crush the plastic ring that holds it to box. Once it has been crushed, it doesn't last long.
I'm probably going to drill a hole and use a tie-wrap to fix it. I don't want to spring for the new part.
RXFEVER
Aug 29, 2018 10:14 AM
WranglerFan
Nov 5, 2017 09:35 AM
RenzoRx-8
Sep 9, 2015 02:38 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
