Issues with greddy turbo
Old Jul 9, 2005 | 04:50 PM
dodo_croatia's Avatar
jump...
Unhappy Issues with greddy turbo
I have problems after installing the greddy. I know other people had the same problems, but after searching i still cannot find a simple right awnser to the problems.
Major issue is when the car is swiching from closed loop to open loop, and when it tries to hold the closed loop. When i am starting, at low rpm, the car shakes, hesitates, alot! You cant drive slow, you have to force it to open loop. In open loop, at WOT the car works fine, it has a steady AFR (from 1 to 0.9) no backfireing, steady 0.5 bar of boost.
Also the car is not drivable until it warms up, you cant move at all, like he is not getting any fuel or something. Yesterday, outside it was cold and it was raining, car was warmed up. When i tried to go, the car was NOT DRIVABLE, it would not move at all, only when i press like 60% of trottle. I parked the car in the garage, and after 3 hours, the rain stopped, it was little warmer than before and the car ran normally, with hesitation, but as all the time.
Car has stock cat, stock midpipe, racing beat exaust, had cels before (misfire, too rich and 02 sensor voltage too low)
I have the latest greddy harness, with 3 dongle.
Old Jul 10, 2005 | 03:17 AM
jump...
Bump..
Old Jul 10, 2005 | 04:13 AM
thew's Avatar
Thews8
Hey.. hows it going.. !!!!
Sound like you gave it plenity of time to relear the CPU after your install.. ?
Alwyas Tripl check your connections for shorts or reversd wires.. and if all else fail.. Call Greddy
they will be happy to help you work throught it.
Old Jul 10, 2005 | 06:21 AM
jump...
I will check the connections again, thanx.
btw, do you know if my emanage and harness are ok, are they from latest greddy shippment, or old one, that needs to be changed
Mxttz0r
Jul 5, 2019 03:19 AM
Cookingislife1226
Mar 20, 2016 09:51 AM
RicerX1
Jan 11, 2016 05:59 PM
Paul_Y
Sep 21, 2015 02:23 PM
just1jack
Sep 9, 2015 04:45 PM
