Pls advise on rims (technical)
Old Jul 3, 2005 | 12:13 AM
Naughty Boy's Avatar
Question Pls advise on rims (technical)
Hi all! Me looking at rims! :D
Would be grateful for advice on the following, in the context of 19" rims:
1. Will the speedo be affected and if so how? I.e. Will the speedo read lower or higher?
2. Will torque be affected?
3. Will the consumption be worse?
4. What would a good brand of tyre be?
5. Anything else me should look out for?
Me never understood PCD, offset, etc. so pls forgive me for me simple approach :o :p What other cars can fit the rims (which would fit our RX)?
Thanx all - and wish me luck! :D
Old Jul 3, 2005 | 01:13 AM
cuscorex's Avatar
爆 走 RE风 林 火 山
mayb tis shld b able to gv u a rough guide on ur 1st q
http://miata.net/garage/tirecalc.html
2-3)torque,yes,it'l b affected,slower,in fact.if u r gona use wider rubbers,FC is gona go dn too,but u xchg it 4 better road holdin...
4)rubbers,dpends on ur budget...fr korean's kumho to japan's advan,ur 'willingness' to spent plays a part;u r tokin bout 19s here.i wud suggest st115 fr falken.a balance on performance & noise.
5)hmmm...if u hv plans to upgrade ur calipers,remem to go 4 a wider offset;>43 to play safe.pcd will b standard;114.3/5,no worries on tat...
Old Jul 3, 2005 | 04:56 AM
EBS's Avatar
EBS
Hi
Agree with bro Cuscorex. Just a bit more info.
1. Speedo is tune to stock rim/tyre size. It depends on the rolling diameter so if the upgraded rim/tyre is the same as stock, then speedo will not differ or else it will either read faster or slower than actual depending on the new rolling diameter comapred to the stock.
2. Torque I assume u mean pick up at the wheels. Bigger rims/wider tyres usually mean slower pick up which is why some people downsize their wheels when they track. 19" looks good though.
3. For branded tyres (top of range), 19" tyres shld be at least $350.
My friend just bot the Japan Bridgestone 18" S02 at $330 per piece.
4. Consider overall weight for the package. U will be surprised how heavy the tyres are so expect running cost to increase. If u 'know' what after mkt brakes u are likely to go for in the future, this will help in selecting the right offset. Diff rim design with the same offset can have diff result clearing big brake calipers!
So far not many with 19" rims if I am not wrong.
Cheers
Old Jul 3, 2005 | 05:45 AM
coupe07's Avatar
SC 300HP!!
Originally Posted by EBS
Hi
Cheers
bro, do u wan to join for fridays' nite gathering? give me ur hp no. so that can inform u!!
only tok to u during polo tee's collection day.....
Old Jul 3, 2005 | 07:12 AM
Yo Cuscorex! Thanx for u pro advice - the calculator's a fantastic find!
Happened to go for the car show today and saw your ride - u design is N-I-C-E! Me tempted to try too! :D
Old Jul 3, 2005 | 07:15 AM
Hi
Cheers
Thanx EBS. Have we met before at the meet?
Me grateful to u 'technically inclined' types here - so me can concentrate on the visual side of things! :D :p
Old Jul 3, 2005 | 07:17 AM
Yo Coupe07! U sms'd me at the meet on Friday, so u must have me no.! :D
And pls keep me informed on all meets - me will try to attend. Thanx & cheers!
Old Jul 3, 2005 | 07:18 AM
Thanx all for u tips & advice!
But me curious (and naughty :D )
Will the rims for our RX fit any other car (e.g. RX7 )
Just in case... :D
Old Jul 3, 2005 | 08:50 AM
EBS's Avatar
EBS
Cannot leh. Working nite shift everyday until 2 am. Thats why always missing .
Old Jul 3, 2005 | 09:26 AM
lennon's Avatar
Just in case... :D
Well it depends on your offset. The best offset for RX8 is 40 front & back.
Old Jul 4, 2005 | 08:22 AM
Genesis's Avatar
Driving Me Crazy
In many cases yes, but not always. Have a look at an earlier thread https://www.rx8club.com/far-east-asia-38/rx8-rims-offset-58888/
Notice Taka's comment: "I have to add. There is a slight variant in the offset among designs. You see the offset is measure from the center of the rim to the central plate (where the nuts are). You see if the central plate is design to be further in the rim... then their offset will be less positive."
So it really depends on the dimensions of the rim, need to take the measurements to be sure. My LE37's are only +30 offset, but perfectly line up with the edge of the fenders.
Old Jul 4, 2005 | 08:33 AM
lennon's Avatar
Noted. My Mazdaspeed rims fit well with lower suspension.
Old Jul 4, 2005 | 10:17 AM
lohsk's Avatar
"Beng Your Ride"
Just in case... :D
Look here my friend... if and when the new car comes and it's negative offset... get spacers, if positive offset, get a widebody kit.
So simple.
:D
Old Jul 4, 2005 | 11:06 AM
sqflyer's Avatar
Heavy Machinery Operator
Anything to take note about using spacers?
Old Jul 4, 2005 | 01:41 PM
Mockngbrd's Avatar
Veilside liao ar....mai tu liao..
Or wanto try Ab-Flug?
Old Jul 4, 2005 | 02:29 PM
lohsk's Avatar
"Beng Your Ride"
I think Naughty Boy is refering to veilside rims and not the body kit.
Old Jul 4, 2005 | 10:30 PM
M-ster's Avatar
sorry side track abit, can someone tell me wat is FRP? Wat material is that?
Old Jul 4, 2005 | 10:41 PM
lohsk's Avatar
"Beng Your Ride"
Not sure but you could see this web http://claymore.engineer.gvsu.edu/~j...ufact-254.html
Old Jul 4, 2005 | 10:47 PM
Mockngbrd's Avatar
no la..i showing notti boy AB-Flug rims
Old Jul 5, 2005 | 12:22 AM
coupe07's Avatar
SC 300HP!!
bro, FRP is Fibre Reinforced Plastic. Very good material used by the japanese to fabricate their bodykit.
Old Jul 5, 2005 | 01:02 AM
lohsk's Avatar
"Beng Your Ride"
Are those rims manufacture by Ab Flug ?? Cool... didn't find it on their web site.
Old Jul 5, 2005 | 01:39 AM
M-ster's Avatar
Thanks Ioshk & 07!
Old Jul 5, 2005 | 01:44 AM
M-ster's Avatar
Any idea where else beside Japanparts.com can i find Abflug?
Old Jul 5, 2005 | 02:28 AM
M-ster's Avatar
Think NaughtyBoy already has his eye on this rim...
Old Jul 5, 2005 | 07:06 AM
lohsk's Avatar
"Beng Your Ride"
Well if you can understand Japanese http://www.ab-flug.co.jp/
They have an online catalog.
