damn, stipped nut...
Old Jun 29, 2005 | 10:48 AM
x-ped's Avatar
Well last night I was installing rear racing beat springs and what a pita. The drivers side endlink was on there so tight, I stripped the bolt. I can't see what I did wrong, I used the correct size socket. Is there a way too get the nut off so I can save the endlink? Or should I just buy a new endlink and drill/cut it off? Any help would be great.
Old Jun 29, 2005 | 10:55 AM
modena's Avatar
Modena
Happened to me to
Try taking of the sway bar; remove the clamps that hold it on.
It should give you enough clearance to take the shocks out....
Old Jun 29, 2005 | 10:59 AM
subduedracer's Avatar
Realtor1
Get a standard socket that is a little small. Hammer it on and break it lose.
Old Jun 29, 2005 | 11:58 AM
Go48's Avatar
You mean you rounded the head of the bolt or stripped the threads? If you just rounded the head, go to sears and get a tool that will grab the head regardless of size. I don't recall what they call it , but they will know.
EDIT: Craftsman 5-piece Add-on Bolt-out Set. Also includes removers ...fits standard sizes 5/16, 11/16, and 3/4 in. Fits metric sizes 8, 10, 13, and 19 mm. Item #0952161. Set=$19.99
They have other sets as well.
Old Jun 29, 2005 | 12:18 PM
x-ped's Avatar
Thanks guys, ill try to get it off today.
FubarI33t
Sep 28, 2015 08:45 PM
Aston177
Sep 3, 2015 11:07 PM
HMSS013
Aug 28, 2015 03:02 PM
tigg.z
Aug 26, 2015 09:51 PM
Rx808BI
Aug 9, 2015 10:06 AM
