A "clunk" over bumps
Old Jun 27, 2005 | 05:52 PM
MI_FamilyMan's Avatar
Sold on Rotaries!
When I go over sudden bumps such as a pothole, I can hear a "clunk" coming from outside the vehicle when I have my windows down. This is the only time I hear the noise. It is somewhat metallic sounding, kind of like as if the wheel center caps were loose and making a "clank".
Does anyone have an idea what this might be and if it is an issue or not? Hopefully I can just tighten up something and have it go away?
Old Jun 27, 2005 | 05:55 PM
MazdaManiac's Avatar
It is likely that your exhaust system is banging into a crossmember or the underpan of the car.
The rubber that mounts the pipes is very soft.
Old Jun 27, 2005 | 06:07 PM
Tamas's Avatar
Registered Lunatic
I have the same type noise. It's annoying. Hopefully it is not something that can cause a problem.
Old Jun 27, 2005 | 07:01 PM
ethernetgeek's Avatar
Evil Genius
I feel your pain as well. I just noticed it a few weeks ago as the temperatures started to climb.
-Gary
Old Jun 27, 2005 | 07:20 PM
atl8's Avatar
If you think it's coming from the front wheels it might be this -
https://www.rx8club.com/showthread.p...threadid=13410
Old Jun 27, 2005 | 07:48 PM
vwnh's Avatar
Moe
I had the same problem. I had an rx8 store exhaust that was hitting something when i went over bumps. I had a garage put some hangers on, went away. I have also noticed that when it gets hot out i have a sound coming from under the dash sounds like change rattleing or something . I found that when the inside of the car is very hot their is a clip holding a wiring harness under the dash near the gas pedal that rattles. put some tape on it and no more rattle. Hope this helps.
Old Jun 27, 2005 | 08:10 PM
Sold on Rotaries!
Can't make out the picture too well, but if I had to guess, the noise is probably coming from the rear left.
Old Jun 27, 2005 | 08:11 PM
Sold on Rotaries!
Thanks for the tip. It is not all that disturbing to me, since it only happens when I hit a decent bump. Unfortunately around here that is pretty often. But if it's not a big problem, I can probably live with it for a while.
Trekk
12
Sep 25, 2015 03:08 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
Paul_Y
Sep 21, 2015 02:23 PM
GrAfiX
Aug 24, 2015 08:08 AM
