Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Does your 8 run hot in the Texas heat?
Old Jun 25, 2005 | 09:34 PM
dmorales's Avatar
Spin Triangles! Spin!
Just curious, today I really noticed that when I drive when it's really hot out (90+) My car seems to run hot. For example, it was about 98 today and I was driving normal, not hard or anything, and when I turned off my car the fan kicked right on and stayed on for a while. It did that all day, every time I stopped.
The funny thing is my temp gauge doesn't show that the engine is getting too hot.
Is this normal with yall too?
Sorry, just worried about my beautiful rx8! :D
________
College Girls Cams
Old Jun 25, 2005 | 09:41 PM
Hellblazer's Avatar
Rotor Power Rules!
Normal on my car. Drove from work to home (about 15 miles @95 degrees) and as soon as I turned the car off the fan kicked on for about 10 minutes. It doesn't do it always but it does happen.
Old Jun 25, 2005 | 09:44 PM
j-apex rx's Avatar
that's normal ,if it doesn't turn on then you should worry.
Old Jun 25, 2005 | 10:05 PM
dmorales's Avatar
Why does it need to stay on if the engine is already cool enough?
Well, as long as its ok, I'm relieved!
________
The Peak Towers Prathumnak
Old Jun 25, 2005 | 10:41 PM
ALWAZL8's Avatar
Who's Al? It means ALWAYS
I second that...
Old Jun 26, 2005 | 03:53 AM
xxsunsooxx's Avatar
yea mine does that too but it seems even in my garage after not driving it for a few hrs the hood is still hot.. and the engine is as well.
Old Jun 26, 2005 | 09:52 AM
jenkins-crew's Avatar
Got to love rotarys, they run hot!
Old Jun 27, 2005 | 04:18 PM
bluesunlion's Avatar
my other car is blue
The fan continuing to run after the car is shut off is completely normal in hot weather, as well as the "heat soak" that happens to the hood after it's been shut off for quite some time.
Rotaries by nature run a bit hotter than piston engines.
Also, the temp gauge in the 8 is more of an indicator rather than a gauge. Kind of like the oil light, it registers the "ohshit" extremes rather than particular ranges or levels.
(personally, I like real gauges much better, but oh well.)
If the fan is still running, the engine isn't "cool enough" yet. It should turn off whenever it reaches that threshold.
Old Aug 3, 2005 | 09:39 AM
gorally's Avatar
How much impact will that be to the battery? Wouldn't running it for 10 mins will drank the battery pretty fast?
Old Aug 3, 2005 | 09:45 AM
dazygirl415's Avatar
I wouldn't think so. I've had my fan run for much longer than 10 min before and I've never had a problem with the battery charge. I'd think the fan was designed to use minimal power since it's used almost all the time.
Old Aug 3, 2005 | 10:39 AM
DreRX8's Avatar
Normal for me--I just try not to turn up my soundsytem too loud in the middle of the day unless I have the pass through off to let off the heat.
Billy Marcial
Mar 1, 2018 06:50 AM
wanted797
Aug 26, 2015 11:24 PM
dbarber
Jul 25, 2015 01:34 PM
