Where does the condensate from the A/C go
Old Jun 25, 2005 | 05:49 PM
MDRX8's Avatar
Where does the condensate from the A/C go? My piece of crap A/C does not produce enough condensate to hit the ground. Does anyone have that does. A/C at 50. My Tahoe hits 40 degree's and below no problem. Back to the dealship we go. No. 4 times...........
Old Jun 25, 2005 | 05:51 PM
r0tor's Avatar
with the newest refridgerants your lucky if you can hit 55 degrees
Old Jun 25, 2005 | 06:08 PM
Go48's Avatar
Do you live in an arid climate? No moisture in the air translates to little condensate. But you know that already.
If you live where there is appreciable humidity, you should be producing obvious condensate. If not, the drain pipe may be plugged or misdirected. My car produces copious amounts of condensate and leaves good sized puddles on the garage floor.
Old Jun 25, 2005 | 06:44 PM
NavyDood's Avatar
Who is this Navy guy?
Um, what refrigerant are you referring to? I converted my 1985 Toyota 4Runner from R-12 to R-134a and I can get to 42°F easily. That is with a thermometer stuck in the air outlet at the farthest away point.
As for the condensation, it all depends on the humidity level. The most I have ever seen from the RX-8 is about a saucer sized amount on the garage floor here in TX.
Old Jun 25, 2005 | 07:13 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Originally Posted by abbid
My 8 has never condensated. Period.
Same here
Old Jun 25, 2005 | 07:39 PM
r0tor's Avatar
well, i'm apparently not the only one that has experieinced this...
few results from R12 vs R134a from google...
http://autorepair.about.com/library/...afpr120704.htm (near bottom)
http://www.refrigeration-engineer.co...hp/t-1047.html
Old Jun 25, 2005 | 07:54 PM
Gyro's Avatar
Rotary Abuser
With high relative humidity, my RX8 left a puddle the size of a dinner plate on the ground after I let it idle for 20 minutes today.
Also, if you have it on "recirculate" it will produce less moisture. The cabin air gets dehumidified and it continues to use the drier air in the HVAC system over and over again. On "fresh" it pulls warm humid air continuously from outside and will create alot of condensation. The system is essentialy working harder in this mode, and is why it is recommended in the manual to use "recirc" to get the max efficiency.
Old Jun 25, 2005 | 08:28 PM
MDRX8's Avatar
Condensate
I live in SC so I know I should be producing puddles under the car... Thanks guys This gives me a little more info to find out where my A/C problem is.
Old Jun 25, 2005 | 08:30 PM
MDRX8's Avatar
PS if I used fresh air my A/C tmp would be about 64.
Old Jun 26, 2005 | 11:29 AM
slaxer07's Avatar
I've seen r-134 hit 33 degs. can't ask for much better then that.
Old Jun 26, 2005 | 11:31 AM
slaxer07's Avatar
Both your links are talking about after you have retro-fitted from r12 to r134a does not apply at all to the 8.
RevMeHarder
Jun 1, 2026 02:30 PM
nadodave
Aug 28, 2019 05:55 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
djp6783
Sep 19, 2015 12:12 PM
