How do I install Headlight Bulbs H7 ??
Old Jun 24, 2005 | 05:02 PM
Ktreece777's Avatar
I have searched this and no luck... i have removed the plastic behind the headlights and cannot reach them.... I also pulled my bumper off but could not figure out how to take the healights off and didnt want to mess up the adjustment so someone can you please tell me how do I change my headlight blubs???
Old Jun 25, 2005 | 05:08 AM
gbak's Avatar
the only way to get access to this point is through the wheel area...so you must turn fully right or left the wheels and remove the front cover.....
Old Jun 25, 2005 | 06:38 AM
Xyntax's Avatar
THREAD KILLER
Yup, through the wheel area:
- Take off the rubber sleeve protecting the bulb
- Unhook the brace
- Slowly take out the bulb assembly (take note of the frame position)
- Detach the H7 unit from the plastic frame holder
- Attach the new H7 unit to the plastic frame holder
- Insert bulb assembly in its original position (careful not to touch the bulb glass to anything)
- Lock the assembly with the brace
- Hooking up the brace back is a tough one. I found an easy method. Find a hollow tube (pen, tool, etc) that is about 2mm in diameter. Push the brace **** using the hollow tube all the way to the deep end until it clicks. I used to have sore fingers doing this during my first time.
- Attach the rubber sleeve and finish up by closing the wheel well
...Do these steps for both sides. Oh and may I recommend Sylvannia SilverStars H7s :D
Old Jun 26, 2005 | 12:36 AM
Ktreece777's Avatar
So should I remove my wheel because im afriad of touching the bulb its hard to get to that stuff in there... or can it be done?
Old Jun 26, 2005 | 05:46 AM
gbak's Avatar
try to jack the car only without remove the wheel...........its better you have more access but be careful with these retainers...
Old Jun 29, 2005 | 12:31 AM
This needs to go into the DYI or something.
Old Jun 29, 2005 | 12:17 PM
Frank Patrick's Avatar
Retainer clip housing very fragile
When re-inserting the retainer clip, which slips into a plastic housing, do not simply bend and snap into position- you may break the plastic catch point. Carefully release spring tension, while sliping into place.
just a bit of scar tissue I wish to share!
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
arexatemate
Oct 9, 2015 06:23 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
