Where to easily connect to headlights?
Old Jun 21, 2005 | 10:05 PM
humagin's Avatar
hey guys i need some help.....ive searched this forum and i coudnt find what exactly i was looking for but here goes.
Im tryin to install red neon lights, the thing is, i want it to turn on/off when i turn my headlights on/off....Where is the easiest place to connect to the headlights?
I would like to achieve this result but I need to know where to easily connect to the headlight:
https://www.rx8club.com/attachment.p...chmentid=52979
Detail info w/pics if possible will be greatly appreciated
thanks for any info guys!!!!
Old Jun 21, 2005 | 10:11 PM
kuleto's Avatar
this may be a first...
Old Jun 21, 2005 | 10:27 PM
humagin's Avatar
Originally Posted by abbid
Why not just attach it to the side marker?
I am sorry, what do you mean by side marker, please explain.
Old Jun 21, 2005 | 10:38 PM
kmg1186's Avatar
I have an RX-8. Cool.
As in the turn signal on the side of the car that people replace with clear corners. Correct me if I'm wrong.
Old Jun 21, 2005 | 10:49 PM
cLLcLe's Avatar
Just call me Circle
Oh wow... you really want that? Isn't it illegal to drive around with neons on... if you wire it like that then wont that mean that neons will always stay on while you are driving?
Good luck with your project though. ^^
Old Jun 21, 2005 | 10:57 PM
dazygirl415's Avatar
Count this as a request for two... I want the neons outside and inside to both come on when I turn on my headlights, but I don't know where I can wire into.
Old Jun 21, 2005 | 11:05 PM
clmantis21's Avatar
DONT DO IT you're just asking for a ticket
Old Jun 22, 2005 | 07:50 AM
StewC625's Avatar
Insanely Yellow
Red neon? Like that stupid-*** looking underbody glow crap?
Please don't do it. You'll run the risk of branding the rest of us just a bunch of ricers.
Old Jun 22, 2005 | 09:33 AM
Frostee's Avatar
I am Goober Wafflelips
would that not increase the load on the side marker, possibly making it more dim when lit?
PS - im not that savvy when it comes to electronic wiring on cars, so this one of the things that popped into my head :D
Old Jun 22, 2005 | 09:42 AM
Glyphon's Avatar
脾臓が痛みました
i'd say you'd be better off just wiring it to its own switch so that if you do end up with problems from the police, you can still turn the neon off without having to turn your headlights off, which could make it difficult drive at night, not to mention illegal.
Old Jun 22, 2005 | 09:44 AM
StealthTL's Avatar
Metatron
But if you DO.....
I would wire it from the trunk.
Splice into the wire to the rear running lights, it's the red/black wire, just move the carpet & liner.
Put a switch in the power line, so you can turn it off when the officer says so. Run the wires out of the rubber grommet above the muffler. Done.
S
Old Jun 22, 2005 | 09:49 AM
MTCD01's Avatar
KMG1186 - It wouln't be an issue. You'd actuall just run a hot lead from the marker to a relay (the relay would then draw power from the battery).
As everyone else has noted exterior neon is illegal when driving so you'd want a switch on the remote lead anyway.
Old Jun 22, 2005 | 10:57 AM
Parmer8's Avatar
Maybe you could wire it to the fog lights. At least you can turn it on/off from the factory switch.
Old Jun 22, 2005 | 06:03 PM
humagin's Avatar
Thank you guys for all your replies.
I finally decided not to do it. It is too much trouble. My next mod will be red strakes instead. I think it is way better .I have seen 3 on each side of a red RX8 and it looks amazing. They are just hard to get
Thanks again!
Shankapotamus3
Mar 14, 2021 03:53 PM
archon
Oct 1, 2015 06:08 AM
He||hammer
Sep 29, 2015 09:40 PM
drlubell
Sep 26, 2015 11:58 PM
