Need Interpretation of invoice
Old Jun 17, 2005 | 04:59 AM
SilverEIGHT's Avatar
My invoice on my 7,500 mile service job has this as a line item. Can anyone tell me what it actually means and which flash it is? My car is an 05 GT M/T.
C/S CHECK FOR PCM UPDATES
CAUSE: WAS SW-N3K7E0000 UPDATED TO SW-N3K7ED000
F0010XFX POWERTRAIN CONTROL MODULE - REFLASHING
77 WM4 0.30
Old Jun 17, 2005 | 06:19 AM
Go48's Avatar
77 WM4 0.30
Check out p.2 of the Service Bulletin at the link below and you will see that this update (SW-N3K7ED000) is one step "higher" than the update indicated in the table for your car. I believe the update in that SB was for level "N", in which case your PCM likely was updated to "P". In any case, you can probably assume that IF they updated their WDS prior to flashing the PCM, you have the latest update.
I believe "WM4 0.30" refers to the level of the WDS (i.e., 40.3)--the computer used to update the PCM. Not sure why it would be stated in that manner on the service order.
http://www.finishlineperformance.com...07-05-1432.pdf
Old Jun 17, 2005 | 11:50 AM
zoom44's Avatar
what he said except i think that stuff at the bottom is just their warrenty claim info
TuPaK
Purchasing, Financing, & Insurance
10
Nov 19, 2003 08:04 PM
crossev
9
Nov 19, 2003 07:48 PM
ProtoConVert
Sep 29, 2003 04:29 PM
1fine8
15
Sep 17, 2003 09:44 PM
hannibal
Jan 11, 2003 05:57 PM
