Headlight "Aim"
Old Jun 8, 2005 | 06:30 AM
BTDRX8's Avatar
Headlight "Aim"
Need some help. Just got my 8 back after 3 weeks of deer repair to the front end. While driving last night, my headligts appeared very bright the first 10 or 15 feet or so, like they were pointed straight down. I had to pretty much put my high beams on to see further in front. Can these things be aimed or positioned differently when repaired, or am i just seeing things and getting used to my car again? Thanks for the help!
Old Jun 8, 2005 | 06:58 AM
ZoomZoomH's Avatar
Mulligan User
yes the headlights can be adjusted for aim, take it in and demand they adjust it correctly
Old Jun 8, 2005 | 01:55 PM
BTDRX8's Avatar
Thanks ZoomZoom, i'll do that. I also noticed a fine scratch in my passenger door, not sure if it's from them or the deer, but they missed it!
Old Jun 8, 2005 | 02:09 PM
RotaryIT's Avatar
Yes, 9000.
Just so you know....I had my HID's swapped for the interior film or residue. When they installed, they did not aim them. I took it back and they gave me the line "they auto level".
If you have HID's then there is a white plastic piece at the rear of the headlight assembly. There is a small hole, and through that hole you will see a shiny little gear. Needs a phillips head screwdriver to turn and adjust. Just in case the are not too bright and dont know how....just like my dealer was.
Old Jun 8, 2005 | 02:15 PM
slllygrl10's Avatar
EX-Member
Can they adjust it up and down or just from side to side?
Old Jun 8, 2005 | 02:16 PM
slllygrl10's Avatar
EX-Member
im going to adjust the passenger side cuz its aimed a bit low. I have to do it one of this days.
Old Jun 8, 2005 | 11:24 PM
BTDRX8's Avatar
yes, after driving tonight in the dark, they are definitely too low....almost to dangerous levels. I do have the HID lights...have to get them to fix....
Thanks for the advice on how to do it yourself!
Shankapotamus3
Mar 14, 2021 03:53 PM
drlubell
Sep 26, 2015 11:58 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
