FI boost/vacuum leaks
Old May 29, 2005 | 06:33 PM
nijelSC's Avatar
hi
Any easy way to locate them?
Old May 29, 2005 | 06:52 PM
Speedrx8er's Avatar
Good question . How you know you got a leak(vacuum/boost gauge)? To prevent mine from leaking. I just went to buy some of them clip clamps and clamp all the hoses I connected when installing the FI.
Old May 29, 2005 | 07:14 PM
nijelSC's Avatar
hi
I hear a whistle from the engine bay when I step on the throttle. But not all the time-only when the engine is under some load. And it disappears in mid and high RPM's.
Rough idle, almost stalls after get off the throttle. Unstable boost.
Old May 30, 2005 | 01:41 AM
Speedrx8er's Avatar
Try harden your BOV. It could be the airinx intake that is making the whistling sound. If you don't have a vacuum/boost gauge. I recommend you get one.
Old May 30, 2005 | 02:47 PM
nijelSC's Avatar
hi
It's a SC.
But anyway thanks.
I located them. Connected compressor, 15 psi pressure, sprayed all over a soap water and...lot of bubbles from a few connections.
Fixed.
Old May 30, 2005 | 02:53 PM
lurch519's Avatar
www.evoperform.com
somewhat dangerous if not familiar with working on motors
with car running, you can spray carb cleaner around each coupling and hose on the intake system, ie at intercooler, turbo, etc, (again be careful) and what should happen is if there is a leak, since the intake is under vacuum, it will suck in the carb cleaner and bog the engine some.
dont know what effects this will have on any sensors (ie MAF), but this is how me and my mechanic friends have checked for leaks in the past.
Old May 30, 2005 | 03:04 PM
Audioslave8's Avatar
what kind of SC do u have?
Old May 30, 2005 | 03:12 PM
nijelSC's Avatar
hi
Click my avatar and go to my vBGarage.
Old May 30, 2005 | 03:15 PM
tracker?! Was expecting to see a SC rx8.... oh well.
Old May 30, 2005 | 03:49 PM
nijelSC's Avatar
hi
Don't have RX-8 yet, but will this week. Just waiting possible after 6/1 incentives.
Old May 31, 2005 | 05:32 PM
no worrys, i dont have an 8 either.
Old May 31, 2005 | 07:12 PM
nijelSC's Avatar
hi
but have 4... with S :D
Old May 31, 2005 | 07:14 PM
haha, yeah...
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Azki23
Jun 27, 2018 03:48 PM
poacherinthezoo
Aug 3, 2016 11:01 PM
DG07
Sep 28, 2015 10:58 AM
