system installation hard?
Old May 28, 2005 | 12:12 AM
LiL BenNy's Avatar
Bubblicious? DEF.
Is it hard to install a system? im not a retard but am no where close to a pro at audio stuff... i can hook up surround sound speakers dvd players and reciever all together... but is it hard to install? i am 95% done building my FG sub boxes and i saw the DIY wireing thing and doesnt look too hard... any audio pro can help me with supplies i might need i have 2 500/1 jl amps and 2 10w6v2's i think i need a 2 gauge (dont know what that means just told by JL) what else do i need? something like a spliter? and something because i have the factory head unit? help would be greatly appriciated.
-benjamin
PS
anyone have any pics of the trunk with all the carpet removed?? curious incase i decide to go forth on this i want to know where to run the wires
Old May 28, 2005 | 12:27 PM
LiL BenNy's Avatar
Bubblicious? DEF.
Old May 28, 2005 | 02:09 PM
forbidden's Avatar
Bose system you need the Audio Control 6XS, non Bose you need the Audio Conrol LC6 + bass remote. You also need to ground direct to the battery. There are numerous threads on the go right now that cover this topic.
Old May 29, 2005 | 11:30 PM
Kel Rx8's Avatar
if your not 1st your last
forbidden i did a search on audio control 6xs and came up with I believe
was a AMP for 189.00 i know im heading in the wrong path
I have bose and plan to add my kicker amp with 1 solar baric
how much are the line converter's and i which one would i need
Old May 30, 2005 | 01:51 AM
shawrf1's Avatar
RX8-less
Amps/Power: Run a 0/1 gauge wire from the battery and through the firewall (make sure it's fused near the battery) and to the trunk. Split the 0/1 into two 4 gauge wires with a fused distro block and run one 4 gauge to each of your amps. You can do the same exact thing for your ground wires. For the remote leads, I used a relay connected to a switch for manual control of my amp remote turn-ons (10-gauge wires).
If you have the patience to do some research to make sense of the above, and you have the confidence to make the first step, then you'll do ok...
This is the site I referenced for my builds: http://www.bcae1.com/
There are some nice calculators for wire gauges, etc. on there, as well as box calculators and more.
Here's a photo of the empty trunk...
Old May 30, 2005 | 12:49 PM
forbidden's Avatar
Here is another good site to reference as well. www.the12volt.com You might see someone there with a familiar name....
Old May 31, 2005 | 12:34 AM
Kel Rx8's Avatar
lil benny what converter you using
Old May 31, 2005 | 02:31 PM
LiL BenNy's Avatar
Bubblicious? DEF.
idk lol i dont have my wires together yet.. audio newbie....
drebbrnator
Dec 27, 2018 07:02 PM
TotalAutoPerformance
Group Buy Center
Sep 2, 2015 01:40 PM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
