Clear corners dificult to put on???
Old May 26, 2005 | 11:15 PM
shorty911's Avatar
so im pretty clueless but im ordering clear corners and im wondering if anyone can explain or give a short summaryof how to put them on..!
-thanks
Ryan
Old May 26, 2005 | 11:24 PM
ZoomZoomH's Avatar
Mulligan User
do a search in the DIY section... tons of instructions...
Old May 26, 2005 | 11:25 PM
teebee's Avatar
This is a very easy mod. Basically they are a direct replacement for the orange light assembly except of course the lense is clear with a amber bulb inside.
To install, you turn your wheel all the way to the side so you can get access to the fender well area, then you remove a few of the plastic connectors that hold the inside plastic trim in place so you can access the screw that holds the corner light in place. Remove the screw, twist the bulb socket to undo it, then you swing out the corner light and it will eventually come all the way out. Then you just put in the new one in reverse order.
Old May 27, 2005 | 12:22 AM
army_rx8's Avatar
X-Sapper
so easy to install.....almost to easy :D
Old May 27, 2005 | 01:19 AM
\\Konig\\'s Avatar
turrrbo!
extremely easy mod
don't sweat it
Old May 27, 2005 | 05:10 AM
MI_FamilyMan's Avatar
Sold on Rotaries!
I am mechanically inept and I took off my bumper put the RB grilles & clear corners in and had the bumper back on looking perfect in about an hour. And that was being extremely careful.
Doing just the clears is real easy, just pop off the four plastic clips per side, pull the wheel well trim back, take off one screw, push on the snap to get the corner out, unplug the corner and plug in the new one. Do the reverse to finish it off.
It will help you to examine your uninstalled clear corner so you know where the snap is, where the sheet metal screw is and how the tab and hook at the front of the part install.
The only other "trick" is to be gentle with the black plastic clips holding the wheel well trim on. It only requires a soft quarter turn and the head in the middle will pop out. Then you can grab the outer ring and just wiggle the clip out.
It should take you about 5-10 mins. to do just the corners.
Old May 27, 2005 | 07:02 AM
LiL BenNy's Avatar
Bubblicious? DEF.
mad easy first mod i ever did to my car... i didnt know what i was doing half the time and still got it!
Old May 27, 2005 | 09:34 AM
Gambit's Avatar
Screw gas mileage
Easy...10 minute job, just turn the wheels out of the way
Old May 27, 2005 | 09:39 AM
Mugatu's Avatar
Even My Dog Searches
there couldn't be an easier mod to do. one screw is all that's holding them in.
Old May 27, 2005 | 10:19 AM
RX-GR8's Avatar
easiest mod yet. :D
Old May 27, 2005 | 09:01 PM
8 is enough's Avatar
to repeat what has been said before it is easy. Just remember the clear corners are a little thicker then the normal corners. I installed mine in 10 mins. but it took me an additional 5 mins. to convince myself that i installed them correctly, because of the thickness.
Old May 27, 2005 | 09:47 PM
therm8's Avatar
Bummed, but bring on OU!
Yeah, but how difficult is it? :p
GARCIAC951
Sep 10, 2015 07:17 PM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
blkswan
Sep 2, 2015 10:04 PM
