Blow-off Valves
Old May 26, 2005 | 05:16 PM
DaveRX8's Avatar
Blow-off Valves
What is the difference between The Greddy Type S, Type RS, and Type R Blow-off valves? Thanks
Old May 26, 2005 | 07:05 PM
Fanman's Avatar
Each one is made for different boost levels. The Type S is the "regular" BOV & has a 37 mm vent opening. The Type RS is new, and has a 40 mm opening. The Type R is pretty much for extremely hi-boost applications. Since most of our kits are running under 10 lbs. of boost, the Type S is more than adequate.
Old May 27, 2005 | 01:03 AM
evilbada1's Avatar
also, type S sounds louder than RS :P
Old May 27, 2005 | 09:48 AM
cretinx's Avatar
Our cars should definately NOT use atmospheric blow off valves (in fact, most cars shouldn't other than older cars and things like turbo hondas).
We should have recirculating BOVs.
Either way its a pain in the *** to install in our car cuz you have to weld it in - leave it to the professionals and let them pick the right one for you unless you're dead set on doing it yourself.
If you don't plan to see more than 15 psi you should be fine with any BOV on the market.
Old May 27, 2005 | 03:53 PM
RX8FOREAL's Avatar
Captain Spaulding
Is there a benefit to having a recirculating BOV with the Greddy turbo ?
Old May 29, 2005 | 01:52 PM
cretinx's Avatar
OK
If you are running an atmospheric blow off valve, when it PSSSHES its going to screw up computer readings because the pressure is going to mysteriously vanish, your computer won't know what to do.
If you recirculate, it'll just go back into the pipes and there won't be a crazy drop in pressure.
The reason you want a blow off valve in any case is because when the throttle body closes, its like all that pressed air slams into a wall, and what's it gonna do? Go back and smash into your turbo, killing the life of the compressor wheel.
Old May 31, 2005 | 12:28 PM
Spyder_doo's Avatar
Turbo'd 5
I have to decide on either the type S or RS. Which one will work better with the Greddy kit boosting about 9 or 10 psi? Will there be any difference between the two bovs?
Thanks,
Jamie
Old May 31, 2005 | 12:57 PM
cretinx's Avatar
Thanks,
Jamie
did you bother to read the thread?
You're going to get stalling everytime you shift if you use them.
Old May 31, 2005 | 02:54 PM
Spyder_doo's Avatar
Turbo'd 5
So do you not have a blow off valve of any sorts? I take it yours doesnt make the whosh noice then right? I read the thread but it seems like everyone with these kits has a BOV on it and they all look to be in the same place. Just wasn't sure about it that's all.
Jamie
Old May 31, 2005 | 03:28 PM
Fanman's Avatar
I have the type S on my car & it works fine (non-recirculating). You just have to play with the adjustments. Some people had it too "soft" & hardened it. For me it was too hard, & I softened it. You have to adjust it a bit & it will work fine. You can use either the Type S or RS, they are both fine. We are running such low boost on our cars it doesn't really matter. It is not like we are at 20-30 psi like some of the Evo's where the BOV will make a big difference.
Old May 31, 2005 | 09:13 PM
Spyder_doo's Avatar
Turbo'd 5
Where and how did you put the BOV on the kit?
Old May 31, 2005 | 10:05 PM
Fanman's Avatar
You put it on the intake pipe (the one that goes into the engine). You get the BOV & the mounting kit (essentially a metal that fits on a flange), then you take that pipe to any welder & get a hole & weld a flange into it, so that the BOV mounts up to it.
Old Jun 1, 2005 | 07:27 AM
Spyder_doo's Avatar
Turbo'd 5
Ok that's what I thought, just wanted to make sure that's how everyone was doing it. Why doesnt the kit come with a bov to begin with? Does it not have anyway of releasing pressure?
Old Jun 1, 2005 | 04:09 PM
Spyder_doo's Avatar
Turbo'd 5
I've found two different mounting flanges for the bovs, an aluminum flange adapter and a Steel Weld-On Flange. Which one do I need?
Thanks,
Jamie
Old Jun 1, 2005 | 04:19 PM
lurch519's Avatar
www.evoperform.com
Thanks,
Jamie
depends on the material that the pipe you are going to mount the BOV to. if you have a steel pipe, use the steel flange. if the pipe is aluminum, then go with the aluminum.
welding steel to aluminum is pretty near impossible. a friend a few years ago had a turbo on his civic, and the piping was steel, and he got the greddy BOV with aluminum flange. he cut his hole and had his buddy weld on the flange, but after they got it tacked down and turned the pipe to complete the welds, when they rolled the pipe to weld it, the thing would just pop right off.
Old Jun 1, 2005 | 04:34 PM
Spyder_doo's Avatar
Turbo'd 5
I know that it matter which material you use, but what metal is the pipe in the Greddy kit made of that you mount the bov to?
Old Jun 1, 2005 | 04:37 PM
Fanman's Avatar
aluminum
Old Jun 1, 2005 | 04:39 PM
lurch519's Avatar
www.evoperform.com
ahhh, sorry.
not 100% sure on the greddy kit, but i would assume that the piping is aluminum, as it doesnt need to withstand high heat and or intense pressure.
Old Jun 1, 2005 | 07:06 PM
Spyder_doo's Avatar
Turbo'd 5
Ok thanks, just making sure before I buy one.
Old Jun 24, 2005 | 10:57 AM
BigOLundh's Avatar
#1 Legend
wait... i thought the greddy kit came with a BOV?
Old Jun 24, 2005 | 01:49 PM
lurch519's Avatar
www.evoperform.com
nope
Old Dec 24, 2006 | 02:49 AM
LiL BenNy's Avatar
Bubblicious? DEF.
reviving fromt the dead... if you have a greddy bov welded on can you still change it or are you stuck with that bov?
Old Dec 24, 2006 | 09:51 PM
mikeschaefer's Avatar
I wanna rock! Rock!
you weld on a flange... a greddy flange will accept greddy BOVs
they also make adapters to switch between certain BOV brands, so if I wanted to switch my Greddy to HKS I could do that using an adapter
WranglerFan
Nov 5, 2017 09:35 AM
Evan Gray
Nov 24, 2015 01:00 AM
Willopap
Oct 29, 2015 11:04 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
