How much does Canzoomer/Emanage and Tuning add?
Old May 24, 2005 | 03:10 PM
HardHitter's Avatar
Well, I don't think I'm going to go with a turbo until later down the line. $5000 for an addition of around only 50-70HP isn't worth it to me, so I'll probably go with a Canzoomer/Emanage and tuning it.
I talked to a guy at a shop today, and he said that I need something that will control the A/F ratio, timing, and all that stuff, the emanage and canzoomer will do this correct? He then said he will tune it on his dyno (taking about an hour or so) and he said I'll see around 15-17HP to the wheels.
For those who have these, what was your addition of HP after tuning?
How much does the Canzoomer/emanage cost and do I need to buy anything else? Are you able to tell the difference and is it worth the money in order to hold me off until my warranty expires for me to get a turbo.
Old May 24, 2005 | 05:52 PM
RX8_Ownz's Avatar
If you tune it right, it is worth the $.
Old May 24, 2005 | 07:12 PM
epitrochoid's Avatar
Riot Controller
canzoomer hit about 250whp on the gtec on a verrrry dangerous tune...pretty safely you can get about 20hp out of it
Old May 24, 2005 | 10:51 PM
Fanman's Avatar
Depends on the car that you have. Out of the box the averages of our cars are all over the place. from an average of 170 to 190 whp. Most people who have getten the CZ are getting about 16-20 whp. With other mods you can get to about 200 whp (from 170 whp). If you are already one of the lean running ones then you may not see as much difference.
Old May 25, 2005 | 10:05 AM
Armaant's Avatar
Armaan
hey where do you get a canzoomer from and how much does it cost? Also i've seen threads about different types of canzoomers. I have a o4' 6 speed what type should I get and any idea's where to get the lowest price on it?
Old May 25, 2005 | 10:16 AM
Mugatu's Avatar
Even My Dog Searches
how about the canzoomer section of this site?
Old May 25, 2005 | 12:27 PM
slavearm's Avatar
Boost Junkie
from 173 to 202 at the wheels. Using my customized tune. Same dyno different day. So these numbers might be a little high.
Old May 25, 2005 | 05:23 PM
r0tor's Avatar
20-30whp is not out of the question from my experience
Old May 25, 2005 | 05:39 PM
Fanman's Avatar
Pretty much can get it at only one place : www.canzoomer.com. Stage 1 = mild tune, stage 2 = aggressive tune, Stage 3 controller = multiple maps. Most people though tune the maps to their cars, so it really doesn't matter whether you get stage 1 or 2, you can adjust it to function optimally for your particular car with the software package & CanScan tool.
Old May 26, 2005 | 10:15 AM
Luke08's Avatar
Ive heard you would have to get a midpipe because the can would burn through the cat quick
Old May 26, 2005 | 01:00 PM
Fanman's Avatar
Canzoomer has a hi-flow unit that is made to withstand the incresed heat. Either get that or get the straightpipe (which won't pass emssions though).
tbiggybig
35
Jul 14, 2022 06:14 PM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
archon
Oct 1, 2015 06:08 AM
Danield97
Sep 30, 2015 05:59 PM
