wire label for line output converter
Old May 24, 2005 | 11:12 AM
BomberNYC's Avatar
just wanted to know if the wires going into the bose amp is labled ( left speaker, right speaker, ground, etc etc). I'm planning on installing an amp using line output converters. I did a search but the pictures are all missing from threads that explain how its done. Any help is much appreciated
Old May 24, 2005 | 01:04 PM
forbidden's Avatar
No they are not labelled at all. What are you adding to the system and more important, what are you using for the LOC?
Old May 24, 2005 | 03:15 PM
BomberNYC's Avatar
i'm no car expert, but what i am planning on adding is an amp. Is there any other way to add an amp wiht out getting an LOC? i know some amps come high inputs but figured that RCA's would be much cleaner looking.
Old May 24, 2005 | 03:36 PM
forbidden's Avatar
Your performance of the system is far superior with a LOC over 99.99% of built in hi-lo level adaptors.
Old May 25, 2005 | 08:21 AM
BomberNYC's Avatar
how many jigawatts of power would i need to power the flux capacitor then? =) you just lost me there. there was an old thread with a wire diagram but the pictures are now missing. anyone happen to save them on thier computers?
Old May 25, 2005 | 01:49 PM
MrWigggles's Avatar
Actually the hi-lo built in converters are active circuits and are usually superior to the Line Output Converters that have to use a transformer which may add distortion at low frequencies and could limit high frequency response.
The hi-lo converter and auto-on function of my MTX amp works great.
If the amp you get has speaker level inputs, at least try them first then go LOC if you have to.
-Mr. Wigggles
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Sep 11, 2016 02:51 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
