can you paint the engine color?
Old May 16, 2005 | 05:30 PM
pritch's Avatar
paint the engine cover a different color?
i was wandering if you could paint the engine cover would it hold up to the heat?
Old May 16, 2005 | 05:37 PM
rodrigo67's Avatar
yup...
You really need to prep the cover. It has an oily substance coating the top.
Old May 16, 2005 | 05:38 PM
truemagellen's Avatar
Attracts tree branches
yes...engine cover doesn't get that hot
many have painted it...but really you need a vinyl pigment dye paint...regular paint may chip/crack or warp
pigment dye paint (like G2) impregnates the plastic with color and so there is no paint to breakdown
here it is: http://www.mazdaparts.com/ProductDet...001-1115703387
you may need a special catalyst chemical to prep the vinyl before painting (since it is a hard plastic)...if you want more info I can find it for you, here is the product:
Old May 16, 2005 | 05:59 PM
pritch's Avatar
how about krylon paint it suppose to bond to any plastics.
Old May 16, 2005 | 06:16 PM
tiggerlee's Avatar
May Cause Anal Leakage
Take truemagellen's advice,get the G2.it's far better for what you want to do with it.
The color will never rub or scratch off. Sure it's a littler more to spend but it's well worth it.
Old May 16, 2005 | 06:23 PM
pritch's Avatar
ok thanks guys
Old May 16, 2005 | 09:32 PM
Morgan's Avatar
Lounge Sweetheart
why doesn't anyone ever paint the air box?
Old May 16, 2005 | 09:36 PM
alleycatinheaven's Avatar
OK, so how'd you keep the grey/chrome lettering on the engine lid?
Old May 17, 2005 | 12:49 AM
tape off the chrome/great
Old May 17, 2005 | 01:08 PM
CGRX8's Avatar
ANGER
[QUOTE=alleycatinheaven]OK, so how'd you keep the grey/chrome lettering on the engine lid?[/QUOT
are you planning to paint the entire cover. you need to leave some of it black IMHO. heres a look at mine.
Old May 17, 2005 | 01:16 PM
tiggerlee's Avatar
^Nice job! That looks great!
Old May 17, 2005 | 03:08 PM
That is some fine detailed taping! Is there a trick to the art?
Old May 17, 2005 | 03:44 PM
apotocki's Avatar
CGRX8 - What paint did you use? I went out to the MazdaParts website and they don;t offer 'green' and since I have a 'green' that's what I want to use.
Any other tricks/tips?
By the way - GREAT JOB! It looks good.
Old May 17, 2005 | 04:18 PM
Morgan's Avatar
Lounge Sweetheart
so why doesn't anyone paint the air box???? *trying this question..AGAIN*
Old May 17, 2005 | 04:23 PM
fray's Avatar
probably because of the difficulty in removing the airbox vs the other's which are just covers.
Old May 17, 2005 | 04:33 PM
Slims8's Avatar
Piston Traitor
I guess they don't want too much color. Personally, I would do it. I have done too much painting in the past on interior and exterior plastic parts and I think I'll leave mine alone. Very nice job guys.
Old May 17, 2005 | 04:58 PM
rodrigo67's Avatar
Morgan and alleycat
ok to alleycat. I didn't tape off the lettering, it seemed like alot of work. I painted the cover yellow, including the lettering and repainted the top of the lettering silver. I used high heat spray ( up to 500 degree's), so there's no question of bubbling. A couple of coats of clear coat high temp and it was done...
Morgan, I didn't paint the air box for 2 reasons. It's a pain in the *** to remove and second, I didn't want to much yellow in the bay. I want some black to offset it. If you noticed the pic of my bay you'll see that I only painted the tops of those covers yellow with the sides painted black, then clear coated. Too much yellow would have looked out of place...
Old May 17, 2005 | 05:24 PM
CGRX8's Avatar
ANGER
Because I when i did it i had an intake on order.
Old May 17, 2005 | 05:26 PM
CGRX8's Avatar
ANGER
thanks here is a post that i did when i painted it i hope it helps...
"The Paint I Used For The Engine Covers Was A "plasti-kate" Import Color Touch Up Spray Paint. I Got It At Pepboys And It Cost $3.50/6 Oz.can (i Needed 2). ALL I DID WASS WASH THE COVERS THOROUGHLY AND LET DRY. THEN I TAPED OFF ALL THE SMOOTH PLASTIC WITH MASKINGTAPE. I APPLIED 2 COATS AND IT DRIED ALMOST RIGHT AWAY. ALL IN ALL IT TOOK ABOUT 2 HRS AND COST 7 BUCKS. It Says It Is For Touch Ups??????(i Would Never Use It For That. I Wanted To Go With A Contrasting Color Like Silver Or Yellow But This One Said Mazda On The Cap And Seemed To Match The Car Exactly. It Looks Lighter In The Picture Because Of The Sun But When Held Next ToTHE CAR They Are 100% Matched. Here Are Some Pic Of The Can"
Old May 19, 2005 | 07:05 PM
pritch's Avatar
how comes i cant get any tape to stick to the cover
Old May 19, 2005 | 08:18 PM
tiggerlee's Avatar
The answer was on page one
Originally Posted by rodrigo67
yup...You really need to prep the cover. It has an oily substance coating the top.
Old May 19, 2005 | 10:10 PM
pritch's Avatar
oh thanks prep it with what?
Old May 20, 2005 | 09:43 AM
galleychief's Avatar
Unbalanced & Unmedicated
Hey CGRX8, does the PlastiKote paint you used specifically mention that it is heat tolerant?
Old May 20, 2005 | 10:00 AM
CGRX8's Avatar
ANGER
no but the cover doesnt get that hot and it has been close to 8 months and i have no signs of cracking or anything. i just hose it off and its like the day i painted it.
Old May 20, 2005 | 10:11 AM
Cool, nice job there. I may have just found a weekend project!
Jazzmeson
Aug 6, 2015 04:34 PM
leavitt
Aug 4, 2015 01:55 PM
Jazzmeson
Jul 31, 2015 01:47 AM
Bamaham
Jul 23, 2015 08:08 AM
