DIY for midpipe + cat?
Old May 16, 2005 | 01:42 AM
Sapphonica's Avatar
PingMobile
Hi,
I haven't been able to find a DIY post for installing a midpipe/hi-flow cat. Since I don't know if there's anything weird or tricky like finding out the exhaust is welded instead of clamped, it would be quite helpful to get the advice of someone who's done it.
Old May 16, 2005 | 09:19 AM
foxman's Avatar
Torque is Good
There are 3 bolts that need to be removed that attach the cat pipe to the manifold pipe.
There is an O2 sensor that needs to be unscrewed from the cat itself.
There are 2 bolts to be removed from the cat pipe where it attachs to the muffler section of the exhaust. There are also two springs on this side that you need to keep and reuse. The nuts are used here to compress the springs over the bolts on the cat pipe.
There is one exhaust hanger near the rear of the cat pipe that needs to lubricated with WD40 or soapy water to slide out the hanger from the rubber boot.
There is a gasket that you should be able to reuse that attaches at the manifold end. There is another gasket of sorts that you should also be able to resuse that attaches at the muffler end. I would also recommend using a silicone gasket such as this:
http://www.acehardware.com/product/i...ductId=1295860
It is really not that hard or complex. Unattach in all of these areas and the reattach along the same lines. Takes a few hours with jackstands. PM if you have specific questions.
Old May 17, 2005 | 08:01 PM
Sapphonica's Avatar
PingMobile
Cool.
Old May 27, 2005 | 01:59 AM
seanlft's Avatar
just wondering if i knock out the combs in the cat converter would any indicator appear ?
Old May 27, 2005 | 09:50 AM
No CAT usually = CEL from rear O2 sensor
Old May 27, 2005 | 10:16 AM
army_rx8's Avatar
X-Sapper
just get a high flow cat......you won't notice teh 1 or 2 hp that you'll lose from not goin gto a striethght pipe..adn no cel's and you still pass emissions (and no gas smell)
Old Jul 13, 2005 | 06:59 PM
High Revving's Avatar
what tools are required to do ur exhaust ?
92trbolzr
May 18, 2025 09:04 AM
mdl0209
May 23, 2019 05:46 PM
XianUnix
Sep 29, 2015 03:48 PM
pjwermuth
Sep 28, 2015 11:36 PM
FubarI33t
Sep 28, 2015 08:45 PM
