problem with downshifting into 2nd wit new clutch
Old May 15, 2005 | 07:49 PM
projectcar's Avatar
i had the SRmotorsport clutch and flywheel installed, and when downshifting into second gear it grinds... especially if i just do it lightly... if i slam it into 2nd it goes... but this happen's about 50%of the time.. the people at the shop mentioned that it might be caused by the clutch hose.....
any comments please?
Old May 16, 2005 | 02:06 PM
lurch519's Avatar
www.evoperform.com
if the pressure plate has a higher clamping force, the stock clutch hose may be flexing from the additional hydraulic pressure and not allowing the clutch to fully disengage
maybe try upgrading to a stainless steel clutch line for better clutch action
Old May 16, 2005 | 08:39 PM
projectcar's Avatar
i do have that
the thing is i do have the stainless steal hose... what u think? i just adjusted my short shifter.. and drove it a little today and seemed better..
Old May 17, 2005 | 09:32 AM
lurch519's Avatar
www.evoperform.com
if you already have the stainless steel clutch hose, it may be that the slave cylinder may be out of adjustment. not sure, if you continue to have problems, take it back to where you got it installed and have them check it out. you should not be grinding going into any gear
Old May 18, 2005 | 03:09 PM
projectcar's Avatar
oic
k will do so
Old May 19, 2005 | 12:22 PM
Charles R. Hill's Avatar
Owner of BHR
The clutch pedal needs to be adjusted. I had the same problem and I am using the ACT Xtreme Duty pressure plate. The factory clutch hose was more than able to deal with the higher plate pressures without flexing. I did install the S.S. hose and the feel improved slightly but it wasn't so bad as to cause engagement issues in the first place. Also make sure that the clutch line is properly bled, whether or not you swap to the S.S. hose.
CRH
Old May 20, 2005 | 12:05 PM
projectcar's Avatar
will do
ok sounds like a plan
xAgyex
Jun 3, 2026 03:47 PM
Dokuji
Nov 1, 2016 02:51 PM
bullbuchanan
26
Mar 24, 2016 12:37 PM
harithac
Aug 26, 2015 09:24 AM
GracefulShanks
Aug 18, 2015 11:40 AM
