Greddy Turbo 8 at the track
Old May 14, 2005 | 02:58 AM
adrian-1's Avatar
Ex- member.
Made it to the dragstrip and I did 4 runs. The first 3 were bad due to wheelhop and 1 misshift grind into 2nd. Below is a link of the 4th run which I had a good launch and no problems shifting but there were other issues......
Dragstrip Video file hosted by Nemesis8 ... (Right click and click "save target as")
This was Temple Academy raceway which isn't very good.
-more expensive
-dip in the strip 3/4 of the way down
-actually meant to be a 1/8 track, shutdown area is too short for 1/4mile
It was my first time there only because I found it was closer to where I live (50 miles away).
I will stick with San Antonio Raceway (75 miles away) and I should make it out there next week.
More videos to come.
Old May 14, 2005 | 03:08 AM
truemagellen's Avatar
Attracts tree branches
sweet....thanks adrian-1!
Old May 14, 2005 | 03:09 AM
wait...how can I download the video????...streetfire usually blocks this...can u give us a download link? thanks
Old May 14, 2005 | 03:18 AM
Nemesis8's Avatar
Bigus Rotus
Originally Posted by adrian-1
The first 3 were bad due to wheelhop....
What are you running for suspension?
Don't feel bad - I still have yet to go. I am going to the track with my mechanic...so hopefully I will fair well. I am still tuning, so maybe in a couple of weeks...
Looks like fun - just don't trash your car.
14.1215 ?
Old May 14, 2005 | 10:04 AM
adrian-1's Avatar
Ex- member.
Link should work.
Suspension stuff... Mazdaspeed springs/shocks, MS front/rear strut bars, MS front/ rear sway bars. I launch at 4k-5k rpm and try to feathered it until I could get traction.
I still need to tune mine, waiting for my canscan to arrive. Using my boost controller, I'm running 7.5psi peak/ 6 psi holding. I also have Mazdamaniacs map loaded, not the latest 05/05 one but the one before.
Not sure if the 14.1 is correct. My other bad runs were in the 14.5-14.8 sec. Before turbo, my best was 15.0, on the 19" axis wheels. Hoping to get into the high 13s with the same 19" wheels/tires. May try different wheels and drag radials after that.
Other upgrades since the 15.0 besides the turbo are racing beat flywheel, bonez clutch disc/plate, RP short shifter.
Old May 14, 2005 | 10:11 AM
army_rx8's Avatar
X-Sapper
^ how is the Bonez clutch? any vibrations or problems? or is is golden..and feels .. well at least runs liek stock?
your times would've been better i think with 18"s for rims.....but who knows.
what size tires are you running?
Old May 14, 2005 | 10:13 AM
army_rx8's Avatar
X-Sapper
yeah i can't download or view the link either
Old May 14, 2005 | 11:56 AM
adrian-1's Avatar
Ex- member.
EDIT: Video link fixed.
The bonez clutch is good. You can feel it grab harder, alittle stiffer than stock but not too noticeable. One gripe is that the engagement point is with the pedal slammed to the floorboard, it needs to be adjusted.
Old May 14, 2005 | 01:27 PM
army_rx8's Avatar
X-Sapper
cool i might have to check out hta tclutch set up...well if mine doesnt' get resolved that is
Old May 14, 2005 | 02:08 PM
cas2themoe's Avatar
PoloRican Rotary
lol yeah me too
Old May 14, 2005 | 07:13 PM
Mugatu's Avatar
Even My Dog Searches
uh, not sure what I'm supposed to see in that video. from what I saw, i could have easily just seen a photo of the timeslip at the end of it.
Old May 14, 2005 | 09:21 PM
Fanman's Avatar
Strange in that you got the hole shot off the Pontiac, but it look like it caught up to you & passed you, yet it says from the timeslip that it ran a 14.41. Did he let up at the end ?
Old May 14, 2005 | 09:29 PM
Moostafa29's Avatar
Storm Trooper
"Something's not right..." :D Congrats on being the first (I think?) to take a turboed 8 to the track. Hopefully after you get it tuned and get some more practice you'll be deep into 13s.
Old May 14, 2005 | 09:51 PM
adrian-1's Avatar
Ex- member.
He actually got the hole shot. You'll see the yellow lights blink on the tree after the green comes on. His back tires passing the staging lights first then mine, I spun for alittle bit.
Old May 15, 2005 | 01:45 PM
mrthundercleese's Avatar
RRDI M.C.C.
no, stock 8s run ~14.5+ with clutch bombs.
Old May 15, 2005 | 01:53 PM
adrian-1's Avatar
Ex- member.
I don't want to break anything so I'm not doing any clutch bombs. I may try launching at alittle higher rpm next week.
Old May 15, 2005 | 04:52 PM
army_rx8's Avatar
X-Sapper
hmm i wouldn't want to break anythign with that kinda added power either.
i've only gone to a 1/8 mile tracke and i sliped the clutch at 3k rpm and got a 9.6 in the 8th (bone stock car):D
but it was a really nice trake that had some pretty fast times.
go to a good track then i bet you'll have a 13s timeD
Old May 15, 2005 | 05:29 PM
r0tor's Avatar
wow, 4500 mph at the end of the 1/4 mile... what are you running, dual jetpacks? :p
Old May 15, 2005 | 05:41 PM
RX-Hawk's Avatar
wtb F/I
Oo PM me when you come out to SAR, I'd like to see a GReddy in person. I live pretty close to SAR.
Old May 15, 2005 | 09:04 PM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
adrian thanks for sharing...don't worry, in time you will do much better!
Old May 15, 2005 | 09:16 PM
buzzardsluck's Avatar
pm or post when your going to be at the SAR id like to come see a turbo 8 myself also
Old May 15, 2005 | 09:46 PM
adrian-1's Avatar
Ex- member.
It's looks like Wednesday, May 25th is my next free day that I can make it to SAR.
Old May 16, 2005 | 12:04 AM
Fanman's Avatar
What type/size of rear tires are you running on your Hiro's ?
I know all about poor tracks. I usually run out at Palmdale. It is 1000's of feet above sea level, hot & the pavement is awful. Different tracks will give you drastically different times.
